which intake? #924389
02/09/11 12:36 PM
02/09/11 12:36 PM
Cumberland County, NJ
coronetkid Offline OP
having a 360 built for my daily driven 87 w100 pickup. this truck is sitting on 33 inch tires. basically stock build. block will be .30 over and the heads will be freshened up.4027596 this is the number on the heads. i will also be installing a slightly better than than stock "RV" cam. i have an edelbrock performer which is on my 318 right now or i have this intake that cam with the 360 casting number 4027596. i was told this was a 340 intake. which would be better for low end and economy? this is just a work/daily driven truck nothing radical.
Re: which intake? [Re: coronetkid] #924390
02/09/11 01:14 PM
02/09/11 01:14 PM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
A dual plane intake would work best for your combo. Low end to mid range power. The Intake you have should be good if it is a dual plane.
Re: which intake? [Re: coronetkid] #924391
02/09/11 07:13 PM
02/09/11 07:13 PM
scratchnfotraction Offline
that performer is about the same as a stock 4-v intake but lighter
I run the LD4b/ld340 intake on my daily driver truck
night and day over the performer intake
on par with the newer eddie rpm airgap
woke my ol truck right up with the voodoo roller cam
Re: which intake? [Re: coronetkid] #924392
02/09/11 09:23 PM
02/09/11 09:23 PM
Iowa
tt76400 Offline
tt76400  Offline
Iowa
Stock 340 or 360 intake will make more power on a 360 than a performer intake! Installed a performer on my Challenger in place of a stock 340 intake and lost a consistent 2 tenths in the 1/4. Ports on the performer are small and designed to work on 318's. The stock 340 and even 360 smog intakes are pretty well designed intakes. The only thing you'll gain by going to a performer on a 360 is a little weight savings.
Re: which intake? [Re: tt76400] #924393
02/10/11 08:54 PM
02/10/11 08:54 PM
so the 340 intake would work well with stock heads?
