ati damper and crank trigger????? for you big block guy #923478
02/08/11 12:15 AM
02/08/11 12:15 AM
nc
E
earthmover Offline OP
E
nc
my buddy is getting some of the small stuff for the 572 and would like to know which crank trigger do you guys run with the ati super damper since you can change the hub to chevy bolt patt. is that what most run the chevy crank trigger or mopar this car will have a vac. pump on it as well thanks mike...
also whats the best vac. pump set up to run on this thing???
Re: ati damper and crank trigger????? for you big block guy [Re: earthmover] #923479
02/08/11 07:57 AM
02/08/11 07:57 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
ATI balance, Mopar pattern hub and a CV products mandrel for the vac pump and alternator. I use a alternator mount from Mike Doty with a built in bracket for the small pick-up. Things are packed in pretty tight on the front of my motor, the smaller pickup will let you use a shorter belt
Re: ati damper and crank trigger????? for you big block guy [Re: Bigcube] #923480
02/08/11 08:47 AM
02/08/11 08:47 AM
nc
E
E
nc
thanks bigcube
Re: ati damper and crank trigger????? for you big block guy [Re: earthmover] #923481
02/08/11 08:52 AM
02/08/11 08:52 AM
ky
68roadrunner Offline
ky
i have the chevy pattern. but then you have to buy the wheel and bracket seperate. i thought i would have more mandrel options this way .
Re: ati damper and crank trigger????? for you big block guy [Re: earthmover] #923482
02/08/11 12:10 PM
02/08/11 12:10 PM
AndyF Offline
AndyF  Offline
I make a crank trigger kit for the Jesel/ATI/MSD combination. Switching over to the Chevy 3 bolt setup gives you more options for dry sump drives and pulleys.
