No front fenderwells? #923415
02/07/11 11:52 PM
02/07/11 11:52 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I just purchased a 68 valiant for a parts car but most of the car is so solid I almost dont want to hack it up. The only real issue from keeping this car complete is someone removed the entire front fenderwells and bracing above the shocks and control arms. Would it be acceptable to just add some down bars in the front to reinforce this area? I dont want to go through the trouble of locating a good front clip.
Re: No front fenderwells? [Re: SLOW67] #923416
02/08/11 12:34 AM
02/08/11 12:34 AM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Yes,just run your down tubes and tie into the shock mount.People been doing it that way since the early days.I always run a kicker bar to help chit from moving around!!!!!!!!
Re: No front fenderwells? [Re: 8secDart] #923417
02/08/11 12:59 AM
02/08/11 12:59 AM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Sounds good What part of Salisbury are you in? Im in China Grove myself
Re: No front fenderwells? [Re: SLOW67] #923418
02/08/11 01:17 AM
02/08/11 01:17 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Can anyone show pics of this,I'm interested as well.
John
Re: No front fenderwells? [Re: jcastle1] #923419
02/08/11 02:02 AM
02/08/11 02:02 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
No picture , but what I did on my Barracuda was I welded a 4"x5" 1/8" plate to the upper part of the firewall, ran the down tubes down from there to the frame about 6" from the radiator support. Tied the shock mount to the down tube. Before welding make sure the fender / door lines are correct, the car body might have sagged some with out the inner fender support. Might have to jack the car up under the transmission crossmember to let the front drop back down.
Re: No front fenderwells? [Re: jcastle1] #923420
02/08/11 02:02 AM
02/08/11 02:02 AM
kalamazoo, MI.
VIPERDUST Offline
VIPERDUST  Offline
kalamazoo, MI.
68 front
Re: No front fenderwells? [Re: 8secDart] #923421
02/08/11 03:07 PM
02/08/11 03:07 PM
TMP66 Offline
TMP66  Offline
And since the early days I can't see why people compromise the strucural integrity by removing the aprons, only to add support bars? I can see adding front support along with the aprons (also done since early days and to remain S/S legal). Early Pro Stockers-pre full chassis comes to mind does makes for improved engine bay room.
For today's bracket cars I think it has more to do with looks than making sense (?)
As far as using the saving weight argument, has any one weighed the aprons & core support vs all the tubing going back in? Not looking for any drama just food for thought
Re: No front fenderwells? [Re: TMP66] #923422
02/08/11 03:26 PM
02/08/11 03:26 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
15 lbs to about 5-7 for CM tubing per side. lets the heat out. ability to get to sparkplugs
Re: No front fenderwells? [Re: TMP66] #923423
02/08/11 06:04 PM
02/08/11 06:04 PM
8secDart Offline
8secDart  Offline
I agree 100%,but this guy said he bought it done.Just trying to help him out!!!!!!!!!!!!!!
I'am in live in Faith but my shop is in Salisbury.Not being a smart A$$ but you must be new to Mopars not to know me.
Lenny
Re: No front fenderwells? [Re: 8secDart] #923424
02/08/11 09:53 PM
02/08/11 09:53 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Here's what mine looks like
Re: No front fenderwells? [Re: 70HemiGTX] #923425
02/09/11 01:38 AM
02/09/11 01:38 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
is the car going to be a streeter or track only? if it's track only relocate the shock mount to the bar & cut away the excess steel, it will allow more room to fit nice flowing headers.
Re: No front fenderwells? [Re: 8secDart] #923426
02/09/11 05:49 PM
02/09/11 05:49 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Lenny
Lenny I've seen your cars around...the wagon and the Dart at a couple cruise-ins and such. I fully agree with all of you on the removal of the fenderwells to be a bad idea, in fact it bothers me as bad a blacked out engine bays on mopars lol but being on a tight budget I cant justify finding a parts car to cut up
Re: No front fenderwells? [Re: SLOW67] #923427
02/09/11 06:01 PM
02/09/11 06:01 PM
8secDart Offline
8secDart  Offline
I can't blame you.That is a lot of work.I think AMD is repoping the inner fenders.I say screw it and leave them out.
Re: No front fenderwells? [Re: VIPERDUST] #923428
02/09/11 07:00 PM
02/09/11 07:00 PM
Indiana
470DART Offline
470DART  Offline
Indiana
68 front
That's how I did mine!
Re: No front fenderwells? [Re: 470DART] #923429
02/09/11 07:18 PM
02/09/11 07:18 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
slow67 where in nc are you ??
Re: No front fenderwells? [Re: earthmover] #923430
02/09/11 07:51 PM
02/09/11 07:51 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I'm in china grove just north of kannapolis
Re: No front fenderwells? [Re: SLOW67] #923431
02/09/11 09:22 PM
02/09/11 09:22 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Re: No front fenderwells? [Re: earthmover] #923432
02/10/11 01:01 AM
02/10/11 01:01 AM
Amherst,NY
challengermike Offline
Amherst,NY
How much fenderwell can be removed without hurting the structure?I had to cut my fenderwells pretty big to get the fenderwell headers to fit threw.Its a 68 dart and a mild 499 is going into it.
Re: No front fenderwells? [Re: challengermike] #923433
02/10/11 03:06 AM
02/10/11 03:06 AM
Canada BC
Steve Barton Offline
Canada BC
Here are a pics of what I did with my 71 Valiant
Homepage Pic's http://www.bluemelon.com/dodgeman/ Steve. New best 1.40 60' 9.99 Et 132.8 mph
Re: No front fenderwells? [Re: Steve Barton] #923434
02/10/11 03:58 AM
02/10/11 03:58 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Do my eyes decieve me?....or is that a Chassisworks A-Arm kit on your Mopar clip...
