I'm trying piece together a rally dash setup for my Cuda and was wanting to see if someone here could tell me what parts will interchange. Here's what I have:
72-74 rally housing with speedo, 7k tach, clock and gauges.
Lens for the above housing (needs some polishing)
3 Switch housing with switches (don't know if it's from a rally or standard dash)
Wiring harness from standard dash
Heater switch panel from standard dash
Here's what else I know I'm missing:
Woodgrain bezels and housing
light bar
Questions:
Will any of the standard dash stuff interchange for the rally setup?
Will any of the 70-71 pieces interchange with 72-74 if I run across them?
Any advice on a economical source for some of these parts?
Thanks for any advice or info on this stuff!
