Scarebird disc brake adapter for A body #923203
02/07/11 07:07 PM
02/07/11 07:07 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I seen these adapters advertised which let you use new calpers and rotors from Napa.
I am wanting to put discs on my 69 Dart which has Crager SS rims 14"--5 on 4.
Will my rims fit with this swap.
Has anyone used those adapters for a swap.
Re: Scarebird disc brake adapter for A body [Re: Dart6pak] #923204
02/07/11 08:01 PM
02/07/11 08:01 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I have a set of these on a68 charger older style i think they have changed the rotors , but on mine i had to run a small thin wheel spacer to clear my cragers 15 inch x 7 rim because it would scrape the caliper .
1969 Dodge Charger 1969 Dodge Superbee
Re: Scarebird disc brake adapter for A body [Re: cjs69mope] #923205
02/07/11 10:31 PM
02/07/11 10:31 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I like my scarebird conversion on my 72 a body. The stock rally wheels clear with no problem.
Re: Scarebird disc brake adapter for A body [Re: Dart6pak] #923206
02/08/11 11:22 AM
02/08/11 11:22 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
I have the same kit.. and i run the SBP 14in rally wheels and tires.
