Re: Who makes 440 mains with .001 less clearance?
[Re: Teamx]
#923104
02/07/11 07:50 PM
02/07/11 07:50 PM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Tim, What bearing are you using now? I had to go the other way (needed more clearance) and used a Federal Mogal bearing instead of a King and got what I needed.
Brian Dunnigan
[Re: Teamx]
#923106
02/08/11 02:20 PM
02/08/11 02:20 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
What about Calico coated bearings? I believe that they are .001 less clearance. Or add K to a part number for coating.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: BCFKody]
#923108
02/08/11 03:54 PM
02/08/11 03:54 PM
Posts: 2,091 Delray beach, Florida
Performance Only
the 142M bearings will yield MORE clearance, not less.
Have you measured everything to know why the clearances are more than you want? crankshaft diameter, housing bore size, etc? hopefully you have the experience to accurately mic the crank and your using the lightest tension possible on your bore guage. every time you wiggle the guage the ball ends can drop .0001 or more into the bearing, keep that in mind.
machine shop owner and engine builder
