sure grip additive #92280
07/21/08 10:49 PM
07/21/08 10:49 PM
minnesota
P
president61 Offline OP
P
minnesota
what are you guys using in your sure grips for additive? Where do you get? thanks
Re: sure grip additive [Re: president61] #92281
07/21/08 10:52 PM
07/21/08 10:52 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Your local Dodge dealership should have Friction Modifier Additive. Just add one 4oz. bottle and you should be good.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: sure grip additive [Re: 70sixpkrt] #92282
07/21/08 11:35 PM
07/21/08 11:35 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
the guy who did my rear end gave me a ford additive. says it works better.?? who knows getting the car going this week.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: sure grip additive [Re: hulmule] #92283
07/21/08 11:50 PM
07/21/08 11:50 PM
Ford, Mopar or independent lube manufacturer.....the sure grip additives are pretty well all the same. I've used ford goop in my sure-grips with no issues. My gear shop uses a bulk product. As long as you have "something" in there, you'll be ok.
Sid
Re: sure grip additive #92284
07/22/08 01:05 AM
07/22/08 01:05 AM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Since Mopar dropped the skunk-oil .... I was using any typical gear-lube with the GM additive. But after Mobil 1 SYN came out ...I have been using that "straight" in cone and clutch SG's....no problemO.
Re: sure grip additive [Re: dOc …] #92285
07/22/08 09:01 AM
07/22/08 09:01 AM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Got mine from Napa, right by the parts counter.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: sure grip additive [Re: klunick] #92286
07/22/08 10:34 AM
07/22/08 10:34 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Do you have a part number?
Re: sure grip additive [Re: mopowers] #92287
07/22/08 11:32 AM
07/22/08 11:32 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Go to the Ford Dealer and get the Ford friction modifyer. It is repackaged spicer lube. It is the good stuff and what Dr. Diff recommends.
Re: sure grip additive [Re: dOc …] #92288
07/22/08 11:47 PM
07/22/08 11:47 PM
Tennessee
HOOVER24K Offline
super street
HOOVER24K  Offline
super street
Tennessee
What he said.
Re: sure grip additive [Re: HOOVER24K] #92289
07/23/08 05:37 PM
07/23/08 05:37 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
The one I got at NAPA was made by CRC, it's called "Trans-X," and meets OEM limited slip requirements for Ford, GM, and Chrysler products. 7 oz., #402508. It was like $8, as I recall.
