Trans slipping #922724
02/07/11 12:40 AM
02/07/11 12:40 AM
Queensland,Australia
T-bar Offline OP
T-bar  Offline OP
I have 727 behind my 496rb when i shift from 2nd to top it slips and revs up slightly and then goes in, this is mainly under hard accelaration. I have phoned a automatic shop (locally) and they suggested some pressure valve isn't working correctly and it needs a linkage from the carb to the auto. The car hasn't got this linkage so is this right and what do i need.
Re: Trans slipping [Re: T-bar] #922725
02/07/11 02:18 AM
02/07/11 02:18 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
unless your tranny has a shift kit in it id say you need a kick down linkage to regulate tv preasure.
Re: Trans slipping [Re: moparsquid] #922726
02/07/11 03:22 AM
02/07/11 03:22 AM
T-bar Offline OP
T-bar  Offline OP
Yes it has a shift kit and a manual reverse valve body as well.
Re: Trans slipping [Re: T-bar] #922727
02/07/11 06:03 AM
02/07/11 06:03 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
A manual VB doesn't require kickdown linkage. Try adjusting your band and doing a fluid/filter change. How many miles on the tranny? New build?
Re: Trans slipping [Re: Hotwheelsjr] #922728
02/07/11 06:21 AM
02/07/11 06:21 AM
T-bar Offline OP
T-bar  Offline OP
Not sure on age or how long since it's been serviced so i probalaly should've gone down that route first i suppose. Thanks for the replies.
Re: Trans slipping [Re: T-bar] #922729
02/07/11 06:32 AM
02/07/11 06:32 AM
Boise
Moparteacher Offline
Boise
A band adjustment won't resolve a flair-up. The intermediate band releases during the 2-3 shift. If the band was sticking or too tight it pulls down instead of flairing up. It sound like you have a problem with the application of the direct clutch.
Re: Trans slipping [Re: Moparteacher] #922730
02/07/11 04:11 PM
02/07/11 04:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the band is way out of adjustment an adjustment will sometimes help flareup on the 2-3 shift.
Re: Trans slipping [Re: T-bar] #922731
02/08/11 02:51 AM
02/08/11 02:51 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
low fluid level can also cause this .
maby add 1 pt and retry .
