My first hemi project #922676
02/06/11 11:49 PM
02/06/11 11:49 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I am in the process of building my first Hemi, and I am wanting to ask a few questions....first, what I have so far.
4.5 bore world block
Ported Stage V heads
Stock sheetmetal valve covers
Mopar dual plane single 4bbl intake
Dominator Rat Roaster intake
mopar 9.5-1 4.5 stroker pistons
My goal is 85 octane, 650+ horsepower 572. I am not wanting to debate the made in china thing, but I am wanting some guidance and ideas on what componenets to use and are compatiable.
This all started with a killer deal on the on the block and heads. I have always wanted a hemi for my 68 charger so it begins.
I am split between the H beam and I beam rods. I am thinking the K1 H beams or the RPM I beams, both have the 1.031 pins and 2.375 rod pins. I know the 2.20 journals are more common for the strokers but the I beams only come with the 2.375 journals.
Next is the crank, Callies? K1? 440 source? Eagle? They all are about the same price, I am more concerned with quality.
Cam selection is going to be mechanical roller. I thought about a flat tappet cam but with the changes in oil and ZDDP elimation made my decision to go roller. Hydraulic roller requires too much work to install. It was suggested to me to get a cam with about 240@.050, .570 lift and 116 lsa and .012-.015 lash. I am open to ideas or suggestions.
Pushrod oiling? Do I need it?
StageV rockers? stock? NWP? Indy?
What will fit with stock sheetmetal valve covers?
That is enough for now..Thanks Tim
Re: My first hemi project [Re: astjp2] #922677
02/07/11 06:07 AM
02/07/11 06:07 AM
QLD Australia
Keith Black® Offline
QLD Australia
.. best place to start -get the book by MoparRich (Rich Nedbal).
http://www.fastmanefi.com/
Darren Beale
Keith Black Racing Engines®
Re: My first hemi project [Re: astjp2] #922678
02/07/11 10:13 AM
02/07/11 10:13 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
85 octane?????
Re: My first hemi project [Re: Hemidavey] #922679
02/07/11 11:09 AM
02/07/11 11:09 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
go with the 2.2 journal crank. you will have to do less grinding on the block to get them to clear.
with a bigger cam and springs and sheet metal valve covers the valve springs will probably rub on them, so you will have to clearance them with a hammer.
perception is 90% of reality
Re: My first hemi project [Re: Keith Black®] #922680
02/07/11 02:42 PM
02/07/11 02:42 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I bought it, and read it. He gives great information and many directions to go, that is why I have specific questions.
Re: My first hemi project [Re: Hemidavey] #922681
02/07/11 04:18 PM
02/07/11 04:18 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Yes, 85 octane, not everywhere I want to travel has premium. I have 100 low lead locally but not on the road
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: My first hemi project [Re: astjp2] #922682
02/07/11 04:22 PM
02/07/11 04:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
85? never heard of that...is that an Alaskan thing? Lowest we have is 87.
Coming soon!!!!
Re: My first hemi project [Re: astjp2] #922683
02/07/11 05:04 PM
02/07/11 05:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
K1 crank and K1 rods , for a 572 you want a 2.2 crank pin for clearance between the rods and the block .
Lose the M1 dual plane , it's not that great a performer on a 426 it'll be a pig on a 572 .
I also agree ? 85 ??? I'd build it for at least 87 , more like 89.
Pushrod oiling might be a good thing , have the lifter bores bushed and have a 1/8" hole drilled in the bushing.
that's a smallish cam in that size motor for your HP goal I would think .
Contact members Performance Only or Compwedgeracing for the K! pieces and some direction on your build.
Re: My first hemi project [Re: JohnRR] #922684
02/07/11 05:12 PM
02/07/11 05:12 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
My elevation here in Utah is about 4-5000' above sea level, that is why the lower octane, at sea level the lowest I can get is 87 or 89, depending on where you are. Thanks for the input. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: My first hemi project [Re: Keith Black®] #922685
02/07/11 06:51 PM
02/07/11 06:51 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
I couldn't agree more. Get Rich's book.
He posts here frequently too.
Also please DO NOT use Indy rockers. Even if you get them for free, delivered by the Victoria Secret ladies, and installed by Penelope Cruz. Just don't do it. Search this forum and DodgeCharger.com and you'll see why.
Rockers: consider Harland, Stage V, RAS. RAS site is http://rockerarms.com/rockerarms.com/Home.html
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: My first hemi project [Re: astjp2] #922686
02/07/11 06:52 PM
02/07/11 06:52 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
9.5 comp with alum heads. That's low so you can run low grade pretty easy. The performance will suffer though. HEMIs are different than wedges, you can run 10.5 comp easy with 92 or 93 octane with those heads, and with full advance on timing. But then again I don not know about your octane ratings. Don't bother with a big cam with that compression (9.5), your wasting your time and fuel.
Re: My first hemi project [Re: DANA60] #922687
02/07/11 10:51 PM
02/07/11 10:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Contact Mopar Rich about a cam. He is a Comp dealer and certainly knows his Hemis and cams. I got mine from him.
Master, again and still
Re: My first hemi project [Re: astjp2] #922688
02/07/11 10:59 PM
02/07/11 10:59 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I would throw the MP dual plane single 4 as far away as you can. A real 9.5-1 compression ratio should do what you want but it will tie in with your camshaft choice. Stock Chrysler rocker arms work great and will clear your valve covers. Pushrod oiling certainly wouldn't hurt. Roller cam sounds like a good idea and I would go the FAST injection system, don't even think about carbs.
Carbs and points ignition are what gave Hemi's a bad rep back in the day.
Sheldon
Re: My first hemi project [Re: Mr.Yuck] #922689
02/08/11 12:48 AM
02/08/11 12:48 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
The octane is based on altitude. High in the rockies means low octane, Alaska is mostly sea level so 89 is the norm there.
I was thinking dechellies shafts, stageV rockers, KB stands. Rick Cassel has fair prices from what I have found on the net. If my budget allows it, I would love to run dual fast man efi on a stageV intake....
Tim
Re: My first hemi project [Re: astjp2] #922690
02/08/11 01:52 AM
02/08/11 01:52 AM
RUNCHARGER Offline
RUNCHARGER  Offline
You'll be much farther off running 40 year old stock rockers and the injection than you will spending the big bucks for fancy rockers and topping it off with carbs.
The motor won't notice the difference the rockers make but boy will it run better, stronger, cleaner and longer with the injection.
My next build is using 40 year old NOS wide pad rockers and the injection, I'm selling all my Holley and Carter carbs so I won't be tempted to use one ever again.
Sheldon
Re: My first hemi project [Re: RUNCHARGER] #922691
02/12/11 10:34 PM
02/12/11 10:34 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I found a K1 crank with 2.20 journal but I have not found a rod that will do the 2.200 big end and a 1.031 little end. Can I bore out the .990 small end on the K1 rods? Or will that make them too thin? It removes .040 of the rod. Tim
Re: My first hemi project [Re: astjp2] #922692
02/13/11 11:17 AM
02/13/11 11:17 AM
Indiana
mt162 Offline
mt162  Offline
Indiana
Why are you against the .990 wristpin?
Re: My first hemi project [Re: mt162] #922693
02/13/11 06:02 PM
02/13/11 06:02 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I already have Wiesco pistons with the 1.030 pins, I was planning on a 2.375 journals but I am open to using the 2.20 journal crank if I can get rods...Tim
Re: My first hemi project [Re: astjp2] #922694
02/20/11 12:09 AM
02/20/11 12:09 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
ok, well I pulled the block out of the box, new world block, and put it up on the stand. Found lots of casting flash in the upper water pump holes and one of the coolant passages at the rear of the block. I am expecting some but the passenger side water pump hole was amost closed off. Then I put a piston in the bore to see if it fit, it almost fell through. What should I have for bore clearnace? Block p# P5153862 and pistons are P4876327 and what rings should i get, mopar doesn't carry the recommended ones anymore. Tim
Re: My first hemi project [Re: astjp2] #922695
02/20/11 04:18 PM
02/20/11 04:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Piston with no rings, rod or crank should fall, you need to get some professional help me thinks .
