old tps question #922647
02/06/11 11:03 PM
02/06/11 11:03 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
99 ram 5.2 auto. if you driving with cruise on and you get the feeling trans is slipping ever once and in awhile... would the tps cause that?
Re: old tps question [Re: BigTerry] #922648
02/07/11 04:11 AM
02/07/11 04:11 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I doubt it.. My '98 SST acts up every now and then. It seems like it's shifting back and forth while at highway speeds. It's barely noticeable but I still switched a few sensors including the TPS. No luck.
It does it when the cruise is off or on.
It does it when the overdrive is off or on.
It's been happening over 3 years so I give up.....
Re: old tps question [Re: 52savoy] #922649
02/07/11 08:49 AM
02/07/11 08:49 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
darn! mine seem to only do it when the cruise is on.. I had the trans rebuilt 2 1/2 years ago it been doing it ever since, recently I had to have the solenoid replace in the trans ...I think the next truck I buy going to have a manual transmission in it!
Re: old tps question [Re: BigTerry] #922650
02/07/11 10:24 AM
02/07/11 10:24 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have an 01 ram, 5.2. It was doing the same thing. Changed the brake light switch under the dash. I had read that would do it. Put additional grounds on teh trans, thinking that was it. Then I asked here and I was told it was the TBS,(is that the same as the TPS?). Anyway, changed it out, no more problem. It was unlocking the convertor and relocking it when you hit a bump in teh road. All fixed now.
Re: old tps question [Re: Dodgeguy101] #922651
02/07/11 09:49 PM
02/07/11 09:49 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
hummm I remember see that here I was hoping someone would have a answer.. thanks!
Re: old tps question [Re: BigTerry] #922652
02/07/11 11:19 PM
02/07/11 11:19 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My '00 Dakota R/T would do it. You could watch the tach and see the rpm flare occasionally. I was sure the converter was unlocking. Finally got bad enough it would do it when the cruise was not on. It was the TPS.
Buddy of mine had the same issue with his '01 3.9. It was also the TPS.
Re: old tps question [Re: slantzilla] #922653
02/08/11 08:38 AM
02/08/11 08:38 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I think I'm going to go ahead and invest in a new tps... truck got 167,000 miles on her it worth it to get a new one!!
