The end of the 4 terminal ballast w the brown wire, connect the brown wire to the other wire on that end & retry it. EDIT I reread your post & you have continuity on both sides of the ballast? did you have this no start prob & that's why you got a new 4 pin ECU? If the ballast has continuity & there's no fire at the blue loop end in run (ign1) I'd trace back to the ign sw for the open & I'd start by seperating the bulkhead & checking the 2 brass terminals for that (run) circuit for corrosion
