Lifters not behaving.. #922444
02/06/11 05:25 PM
02/06/11 05:25 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
Anyone had any problems with hydraulic Comp Cams High Energy lifters pumping up during run in?
I have a new set and some are pumping up and firm and some are not after about two hours of run time. I have 40lbs of oil pressure at idle and 80+ at higher rpm. New in the box for a year and I only submerged them in oil before install, should I have done more?
Thanks..
Re: Lifters not behaving.. [Re: Wolfe440] #922445
02/06/11 09:06 PM
02/06/11 09:06 PM
I'm assuming you cleaned the oil off of the lifter bottoms & slathered on cam paste for the final install for breakin but that's seperate from your prob. Might have to take the ones out/open them up/clean/lube/inspect the insides for anything that doesn't look right
Re: Lifters not behaving.. [Re: RapidRobert] #922446
02/07/11 01:06 AM
02/07/11 01:06 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
Well it looks like one way or the other I have to go back in and find out whats up. They sat on the shelf for a year, some corrosion may have found its way inside of a few. In that case may as well buy a new set and be sure.
I have not put the engine under load, but one person I spoke to said he put his engine under load and drove it around for a while and it cleared up this problem for him once in the past. Just not sure why that would matter.
Re: Lifters not behaving.. [Re: Wolfe440] #922447
02/07/11 01:15 AM
02/07/11 01:15 AM
I'd open the offending ones up & see what you see & as you know return each one to it's orig hole. Holler how it turns out
Re: Lifters not behaving.. [Re: RapidRobert] #922448
02/07/11 01:23 AM
02/07/11 01:23 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
Will do... Thanks!
Re: Lifters not behaving.. [Re: Wolfe440] #922449
02/07/11 04:45 AM
02/07/11 04:45 AM
State of retirement
52savoy Online content
52savoy  Online Content
State of retirement
I would check for dirt and rust in the lifter bores and assemble with a light coat of motor oil or tranny fluid. Don't pump the lifters up. When the motor starts it will fill the lifters.. I've pre-filled lifters and it wasn't worth my time because I had to go back and drain the oil out of the lifters.
Re: Lifters not behaving.. [Re: 52savoy] #922450
02/07/11 04:14 PM
02/07/11 04:14 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Are you sure you adjusting them correctly? By the time you pull valve covers and get ready to a check a lifter some may have bled off by then and appear to bad.
Be sure you have adjustment procedure down. If not check back in. Hydraulics can be tricky sometimes.....take a little experience.
Re: Lifters not behaving.. [Re: Viol8r] #922451
02/07/11 05:22 PM
02/07/11 05:22 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Hydraulic's are usually only tricky if you have adjustable rockers.
Re: Lifters not behaving.. [Re: 62maxwgn] #922452
02/07/11 05:39 PM
02/07/11 05:39 PM
UK
602heavy Offline
602heavy  Offline
UK
Take it for a ride & gun it , that'll sort em out.
Re: Lifters not behaving.. [Re: 602heavy] #922453
02/09/11 09:25 PM
02/09/11 09:25 PM
PA.
3
340rocks Offline
340rocks  Offline
PA.
what part# are they I have 822-16 sb 340 has oiling holes for pushrods but Im staying stock shafts wondering if thats ok
Re: Lifters not behaving.. [Re: 340rocks] #922454
02/09/11 09:32 PM
02/09/11 09:32 PM
yes you're fine
Re: Lifters not behaving.. [Re: RapidRobert] #922455
02/11/11 12:25 AM
02/11/11 12:25 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
Had to walk away from it for a few days, I figured I would try starting it one more time before digging any further. So today I adjusted all the rockers again to 1/2 a turn preload instead of my first setting of 3/4 turn. Started it and this time all the lifters pumped up just fine. I put on an old set of valve covers that I cut the tops off so I could watch things for a while and its all good. I couldn't find any wrong adjustments today doing the preload adjustments a second time, and I don't think the difference of a 1/4 turn preload would make the difference why some lifters pumped up and some didn't last Sunday. Just one of those weird things, but its doing fine now. Thanks!
