Re: Offset Cylinder Boring
[Re: TrWaters]
#922415
02/06/11 05:51 PM
02/06/11 05:51 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
I don't understand your statement/question. What are you looking to do? The "acceptable" level of offset would depend upon the available material thickness. Then keep in mind you'll have to make sure you have piston pin boss to rod clearance. I've moved them up to .060".
[Re: TrWaters]
#922417
02/06/11 07:07 PM
02/06/11 07:07 PM
Posts: 4,206 New York
polyspheric
New York
The change affects the clock position of that piston vs. its crank throw.
Assuming the pin eye as the focal point, an RB has a radius of 1/2 stroke + rod = 8.635", = 54.255" circumference circle, = .151" per degree. That makes any re-location almost invisible, like .030" is 1/5th of a degree.
Someone check my math, please?
Boffin Emeritus
[Re: DavidDean]
#922420
02/06/11 07:46 PM
02/06/11 07:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Good Post Im having to offset the bores of my X block. Im having to shift to the front about .050 to correct wall thickness.There's also some good reading at speedtalk.com.
I dont understand... why not just sleeve it I knew if you wanted a big bore they did it but to correct for core shift or a broken cylinder I would have thought just sleeving it would do
[Re: MR_P_BODY]
#922423
02/07/11 01:39 AM
02/07/11 01:39 AM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
In my case I would have to sleeve 4 cylinders and this X block hasnt been bored at all
[Re: mr_340]
#922425
02/07/11 06:41 AM
02/07/11 06:41 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Boring parallel to the centerline of the crankshaft
I'm curious to what Bob has found by boring offset to the crank centerline? Does this allow a better push on the piston for more torque? I heard the PS guys were doing it several years back. Any results that can be divulged?
It eliminates any odd angle loading(friction)caused by the bore location and allows all pistons and rods to traval in the same plane or designed angle. .Any time you can decrease friction you can gain RPM,HP,TQ.
