dual valve spring...which valve seal? #92239
07/21/08 09:55 PM
07/21/08 09:55 PM
Smith Mtn Lake, VA
K
karls67gtx Offline OP
K
Smith Mtn Lake, VA
I just bought a set of dual valve springs from Doug Herbert and I am wondering if the viton seals are my only option? I tried a set of fel-pro seals designed for dual springs but they do not fit. I would really not like to pull the heads but I guess I might have to. this is a street car with nice solid cam (about 242 duration at .50) I read somewhere else on a post that I shouldn't use the teflon for the street. true? thanks for any help.
-karl
Mopar Man
Re: dual valve spring...which valve seal? [Re: karls67gtx] #92240
07/22/08 07:51 AM
07/22/08 07:51 AM
scratchnfotraction Offline
I went through this last mounth
did not want to pull the heads
got 2nd set of springs and went with a single with damper that droped on with stock seals and no machine work to the head
machine shop said pc seals?,and machine work to valve guide and spring seats with the lunati double springs and damper
I just matched the spring rate and its good for my roller cam so far,6200 rpm
Re: dual valve spring...which valve seal? [Re: scratchnfotraction] #92241
07/22/08 11:59 AM
07/22/08 11:59 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You can run teflon on the street with no trouble. You did already have the spring seats and guides cut, correct?
