70 roadrunner 383 or 440 ? #922382
02/06/11 04:52 PM
02/06/11 04:52 PM
Texas
70Runnerdude Offline OP
Texas
I would like to get some of you alls opinions on this.
I am going to build an engine for my 70 roadrunner wich originaly had a 383. It does not have its original engine so it is not numbers matching. Now I can build a 70 model 440 hp for it or a 70 model 383 hp for it the rebuild would be the same cost pretty much so what would you build the 383 or the 440 and why ?
Thanks for your input.
Re: 70 roadrunner 383 or 440 ? [Re: 70Runnerdude] #922383
02/06/11 04:59 PM
02/06/11 04:59 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
The only way I would consider going with a 383 would be if the rest of the car is stock, as came from the factory: Color, Exhaust, Induction etc. (possible exception for wheels and electronic ignition).
If the car has other mods I would go with a 440.
Re: 70 roadrunner 383 or 440 ? [Re: Pacnorthcuda] #922384
02/06/11 05:05 PM
02/06/11 05:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Go with the 440.
Re: 70 roadrunner 383 or 440 ? [Re: stumpy] #922385
02/06/11 05:47 PM
02/06/11 05:47 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
why do 383's get such a bad rap? i've had both for street cars and never had a problem with 383's. NO FACE BITTING please! 383's are so much cheaper and plentiful.
Re: 70 roadrunner 383 or 440 ? [Re: mikemee1331] #922386
02/06/11 05:52 PM
02/06/11 05:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
For the same money needed to build a 383 you can build a 440 and get more power.
Re: 70 roadrunner 383 or 440 ? [Re: stumpy] #922387
02/06/11 05:56 PM
02/06/11 05:56 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Ask any girl, bigger is alway better
Re: 70 roadrunner 383 or 440 ? [Re: 6PACMAC] #922388
02/06/11 05:57 PM
02/06/11 05:57 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
The narrower "B" block gives some more space to maneuver around the engine compartment... I'd go with a 451 stroker based on the 383 block.
Darren
Re: 70 roadrunner 383 or 440 ? [Re: 6PACMAC] #922389
02/06/11 05:59 PM
02/06/11 05:59 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hot Rodders number 1 rule, repeat after me : "There is no substitute for cubic inches"...
Re: 70 roadrunner 383 or 440 ? [Re: 6PACMAC] #922390
02/06/11 06:02 PM
02/06/11 06:02 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i knew i was setting myself up! but seriously, how much more HP gain is there between 60 or so cubic inches? if it that much of a gain, why were 383's standard equipment in b-bodies instead of the 440?
Re: 70 roadrunner 383 or 440 ? [Re: mikemee1331] #922391
02/06/11 06:09 PM
02/06/11 06:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Mainly because not everyone buying a B body wanted a hot rod. B-bodies were your normal every day driver for a lot of people. There's about 25-30 hp difference but ther's almost 50-60 ft lbs of torque difference. Torque is what moves the car not hp.
Re: 70 roadrunner 383 or 440 ? [Re: stumpy] #922392
02/06/11 06:13 PM
02/06/11 06:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Mainly because not evryone buying a B body wanted a hot rod. .
And a lot still don't!
Re: 70 roadrunner 383 or 440 ? [Re: 70Runnerdude] #922393
02/06/11 06:17 PM
02/06/11 06:17 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Life is short, go for the big cubes.
It's the bigger torque that will move the B-body better.
All things being equal, the 383 has to spin higher, move more air, to make the same HP.
A 383 with the 440 crank (like a 451, but smaller bore) only makes a 438 at .060 over.
If you want fuel efficiency and awesome high end throttle response...........stay 383.
Re: 70 roadrunner 383 or 440 ? [Re: 62maxwgn] #922394
02/06/11 06:17 PM
02/06/11 06:17 PM
...for them we have chevys
Re: 70 roadrunner 383 or 440 ? [Re: 70Runnerdude] #922395
02/06/11 06:43 PM
02/06/11 06:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Kind of a no-brainer, the 383 simply won't pull the same HP/torque the 440 can using the same build criteria
Re: 70 roadrunner 383 or 440 ? [Re: Pacnorthcuda] #922396
02/06/11 06:43 PM
02/06/11 06:43 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I'd build a big-inch low-deck block, 451-500", Stealth heads, make it look as stock as possible, and grin like a Cheshire cat when the thing runs low 12s or high 11s and it goes to & from the track on the freeway. And it looks like just another maybe-runs-high-13s 383 Road Runner.
That's the next combo I want to build if someone steps up on my '64 wagon.
Re: 70 roadrunner 383 or 440 ? [Re: stumpy] #922397
02/06/11 06:58 PM
02/06/11 06:58 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the average guy that bought a 1969 roadrunner got the basic 383 and was a wanna-be hot rodder. if the 440 is so much better than the 383 why was it the the engine of choice of Mopar? why wasn't the 440 even an option for the first year and a half (RR not GTX)? is there really such a big difference for the average guy rebuilding a car especially when 383's are so easy to come by?
Re: 70 roadrunner 383 or 440 ? [Re: 70Runnerdude] #922398
02/06/11 07:27 PM
02/06/11 07:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you don't like switching to the 440, then switch the 383 rotating asasembly to 3.75" stroke or more.
Re: 70 roadrunner 383 or 440 ? [Re: buildanother] #922399
02/06/11 08:00 PM
02/06/11 08:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Cost. The average RR buyer was a young guy without a lot of money to spend to go fast. Back then a $300 upgrade was a bunch of money. It was almost another years worth of payments. In todays world the 440 is just more cost effective. More power for the same money.
Re: 70 roadrunner 383 or 440 ? [Re: screamindriver] #922400
02/06/11 08:11 PM
02/06/11 08:11 PM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
I thought it went....." There's no Replacement for Displacement! "
Re: 70 roadrunner 383 or 440 ? [Re: bomber1965] #922401
02/06/11 09:46 PM
02/06/11 09:46 PM
Alabama
BigMoneyLewis Offline
Alabama
For me personally, I always hate to see cars with the wrong CID engine.
Since 440's were not available in Road Runners until 1972 (except Superbirds and of course as a 440+6 ) Personally I would find a correct dated 383 HP , but that's just how I would do it .
I don't like seeing cars painted the wrong year colors, Dodge bumble bee stripes on Plymouths or 72-74 Chargers , any wheel bigger than 15" ,
and certainly don't like blue or yellow headlights .
Correct hose clamps turn me on more than headers and aluminum intakes.
That's just the kind of guy I am .
If you are building a hot rod , go for the bigger motor.
If you are "restoring" the car , go with the right motor.
That's how I see it.
Greg
gregward@mchsi.com phone 256-852-0955
