70 roadrunner 383 or 440 ?
#922382
02/06/11 04:52 PM
02/06/11 04:52 PM
Posts: 398 Texas
70Runnerdude
Texas
I would like to get some of you alls opinions on this. I am going to build an engine for my 70 roadrunner wich originaly had a 383. It does not have its original engine so it is not numbers matching. Now I can build a 70 model 440 hp for it or a 70 model 383 hp for it the rebuild would be the same cost pretty much so what would you build the 383 or the 440 and why ? Thanks for your input. Dave
Re: 70 roadrunner 383 or 440 ?
[Re: mikemee1331]
#922391
02/06/11 06:09 PM
02/06/11 06:09 PM
Posts: 32,929 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Mainly because not everyone buying a B body wanted a hot rod. B-bodies were your normal every day driver for a lot of people. There's about 25-30 hp difference but ther's almost 50-60 ft lbs of torque difference. Torque is what moves the car not hp.
[Re: stumpy]
#922392
02/06/11 06:13 PM
02/06/11 06:13 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Mainly because not evryone buying a B body wanted a hot rod. .
And a lot still don't!
[Re: 70Runnerdude]
#922393
02/06/11 06:17 PM
02/06/11 06:17 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Life is short, go for the big cubes.
It's the bigger torque that will move the B-body better.
All things being equal, the 383 has to spin higher, move more air, to make the same HP.
A 383 with the 440 crank (like a 451, but smaller bore) only makes a 438 at .060 over.
If you want fuel efficiency and awesome high end throttle response...........stay 383.
[Re: 62maxwgn]
#922394
02/06/11 06:17 PM
02/06/11 06:17 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
...for them we have chevys
[Re: 70Runnerdude]
#922395
02/06/11 06:43 PM
02/06/11 06:43 PM
Posts: 18,157 Mass
DAYCLONA
Mass
the rebuild would be the same cost pretty much so what would you build the 383 or the 440 and why ? Dave
Kind of a no-brainer, the 383 simply won't pull the same HP/torque the 440 can using the same build criteria
[Re: screamindriver]
#922400
02/06/11 08:11 PM
02/06/11 08:11 PM
Posts: 146 rhode island
bomber1965
rhode island
Hot Rodders number 1 rule, repeat after me : "There is no substitute for cubic inches"...
I thought it went....." There's no Replacement for Displacement! "
[Re: mikemee1331]
#922412
02/07/11 02:27 PM
02/07/11 02:27 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
i honestly think us guys in the middle would not see much of a difference, performance wise, between a 440 and a 383.
This isn't rocket science; the 383 and 440 are the same basic engine using the same heads, ect. If you were to build your engine to a nice 1hp per cu then the 440 is going to have 57 more hp all things being equal and that is too much to ignore.
I'll put it another way: you'll give up approximately 15 percent going with the 383.
So, if the choice is between a bone stock 383 or a bone stock 440 and correctness isn't an issue then the choice to go with a 440 is a no-brainer......BUT, If I had an original 383 RR, I would build a 383 or 400 stroker to retain the B engine but with an RB kick.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
