Installing 9 position keyway sprocket on crankshaft ??? #922287
02/06/11 02:24 PM
02/06/11 02:24 PM
Penna
70satelliteguy Offline OP
Penna
I am installing a new Rollmaster timing chain and sprocket(s) on my 440.
It was not very easy to remove the old Rollmaster bottom sprocket off the crank. I had to tap it while turning the crank for quite a while before it finally worked loose and came off. Are these a press on type or should it go on and off fairly easy? How do you guys get these things on and off???
Thanks Mike
Re: Installing 9 position keyway sprocket on crankshaft ??? [Re: 70satelliteguy] #922288
02/06/11 02:31 PM
02/06/11 02:31 PM
AndyF Offline
AndyF  Offline
Sometimes they have a little burr on them.
Re: Installing 9 position keyway sprocket on crankshaft ??? [Re: AndyF] #922289
02/06/11 05:58 PM
02/06/11 05:58 PM
Penna
Penna
Thanks for the reply Andy!!!
Do you mean a burr on the crank or the sprocket? How hard is it normally to get these things on and the crankshaft? I thought it would be pretty easy !
Mike
Re: Installing 9 position keyway sprocket on crankshaft ??? [Re: 70satelliteguy] #922290
02/06/11 06:02 PM
02/06/11 06:02 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You SHOULD need a puller to get the gear off if it and the crank are sized properly. You do not want a loose timing gear as it causes unnecessary harmonics and un-even loading on the crank snout. The cause of many snout failures, often blamed on something else.
You should have to tap it on slightly to install it, and need a puller to remove it.
RIP Monte Smith
Re: Installing 9 position keyway sprocket on crankshaft ??? [Re: 70satelliteguy] #922291
02/06/11 06:04 PM
02/06/11 06:04 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Could be a bur on the gear or even on the key way. I've also seen a little corosion/rust/grim build up on the crank itself cuase a tight fit.
It should slide on and off by hand but not be so loose that it has play.
Re: Installing 9 position keyway sprocket on crankshaft ??? [Re: 70satelliteguy] #922292
02/06/11 06:04 PM
02/06/11 06:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike
They normally slide on and off... no press at all...
sometimes the snout of the crank can be a slight bit
oversize and the gear could be undersized so the stack
up COULD be at the max... could check the snout and
gear with a mic or even a set of calipers to see
where everything is at
Re: Installing 9 position keyway sprocket on crankshaft ??? [Re: 70satelliteguy] #922293
02/06/11 06:05 PM
02/06/11 06:05 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Mike
Depending on the crank mfg, they can vary from a light slip fit to a slight press fit. I use a gear puller, which is the proper way to remove it, but you can also have some success "warming" the gear with a propane torch. Don't go crazy, just a little heat will get it done.
What Andy is referring to, I believe, is that there are burrs that form on the keyway slots of the gear that will cause some issues with fitment. You can dress those down with a small file.
FWIW, I'd rather have a gear that is a slightly tighter fit than loose.
MB
Re: Installing 9 position keyway sprocket on crankshaft ??? [Re: HPMike] #922294
02/06/11 07:40 PM
02/06/11 07:40 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Mike
MB
I heat the gear to about 250 degrees in the oven and it slides right on.
I use a puller to remove it.
