Replacing turn signal flasher? #922117
02/06/11 04:22 AM
02/06/11 04:22 AM
kentucky
roadrunner7020 Offline OP
kentucky
Where is the turn signal flasher located on a 70 b body I know ebody cars have separate flashers for the emergency and the turn signals. I plan on installing a no load flasher tommorow and I can't remember where the turn signal flashers are located.
Thanks in advance
Re: Replacing turn signal flasher? [Re: roadrunner7020] #922118
02/06/11 09:48 AM
02/06/11 09:48 AM
okla.
O
okie Offline
okie  Offline
O
okla.
There is a flasher on each side of the steering collumn. I don't recall which is which. Turn the 4 ways on and listen and then you'll know where the other 1 is. Ronnie
Re: Replacing turn signal flasher? [Re: roadrunner7020] #922119
02/06/11 09:56 AM
02/06/11 09:56 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Turn it on and listen to where it's at. I beleive it's located next to the ash tray.
