Page 5 of 5 1 2 3 4 5
Re: Small block race block [Re: MattW] #922054
08/20/11 12:04 PM
08/20/11 12:04 PM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
Ritter told me he can ma nine his blo k to accept the P5 head. Problem is the head itself. They still have water leak issues. I wanted to build a tall deck P5 hemi motor for 10.5 . But no organization would legalize them in my opinion. A gen3 hemi needs alot more head bolts if your going to a max effort program. Maybe we can get Chryslers engineers to look into redesigning the block and heads to a 18 head stud design. Yes right.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: Small block race block [Re: W8n2DustU] #922055
08/20/11 01:52 PM
08/20/11 01:52 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
They probably wont because of the advantages of using the head. I mean there is alot more to winning races than the engine, but every little bite helps.
As for the G3 extra head bolts i don't think it would be to hard to add the bolts provisions but right now there is no head with the extra bolt soooo.
I would like to now if the G3 aluminum block would work with the P5 head.
Re: Small block race block [Re: MattW] #922056
08/20/11 01:57 PM
08/20/11 01:57 PM
Get-X Offline
Get-X  Offline
I hear that there is a 6 bolt head soon to be released....
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Small block race block [Re: W8n2DustU] #922057
08/20/11 02:36 PM
08/20/11 02:36 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
Give Matt at MBE a call about the P-5.
Re: Small block race block [Re: jim sciortino] #922058
08/20/11 05:19 PM
08/20/11 05:19 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
ZIPPY used to keep a post updated with available R-3/R-4 blocks in the "HOT DEALS" section.
The last time I saw it.
........there were some P-5 machined R-4 blocks in stock.
I can't find the post.
Re: Small block race block [Re: S/ST 3040] #922059
08/20/11 06:02 PM
08/20/11 06:02 PM
Trumbull,CT.
Trumbull,CT.
I think those don't go big.
Really short deck IIRC.
Re: Small block race block [Re: jim sciortino] #922060
08/20/11 07:19 PM
08/20/11 07:19 PM
S/ST 3040 Offline
S/ST 3040  Offline
Yes. 8.600" IIRC
I don't think you can get 400" out of an R-4.
Re: Small block race block [Re: S/ST 3040] #922061
08/20/11 09:33 PM
08/20/11 09:33 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Aussie Pro Stock runs them at 399 cubes generally. Most of the Aussie Pro Stock blocks run around a 8.7"-9.0" deck. I think the R4's are around 8.8"-8.9" standard. Most comp guys will deck them down as far as 8.4" (which basically starts to cut into the bell housing pattern).
AL...
Alan Jones
Re: Small block race block [Re: LA360] #922062
08/20/11 09:51 PM
08/20/11 09:51 PM
S/ST 3040 Offline
S/ST 3040  Offline
Re: Small block race block [Re: S/ST 3040] #922063
08/20/11 10:04 PM
08/20/11 10:04 PM
Dyno
JSL Offline
JSL  Offline
Dyno
Usually run at 8.550" and as low as 8.480"
Re: Small block race block [Re: LA360] #922064
08/21/11 12:18 AM
08/21/11 12:18 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
The Aussie heads are an exact copy, right down to the cracks apparently.
AL...
I like BOOST!!!
That's not a combo that would want to work very well with Turbos.
And if the heads are prone to leaks/cracks. Turbos would definitely find them.
Re: Small block race block [Re: S/ST 3040] #922065
08/21/11 06:27 AM
08/21/11 06:27 AM
LA360 Offline
LA360  Offline
Thanks for the correction! They still squeeze 400 cubes into those things!
Alan Jones
Re: Small block race block [Re: LA360] #922066
08/21/11 11:15 PM
08/21/11 11:15 PM
LA360 Offline
LA360  Offline
I would like to publicly retract the off the cuff comment made about the Aussie P5 heads. I based it on what has turned out to be misinformed information and Con @ PRE (He produces these heads) has been more than willing to show me in person his castings improvements over the factory produced units. I think we sometimes forget that what may consider passing comments can have an negative impact on others to which I apologize. I won't be doing it again!
Alan Jones
Re: Small block race block [Re: LA360] #922067
08/21/11 11:36 PM
08/21/11 11:36 PM
Trumbull,CT.
Trumbull,CT.
We've heard the new P-5 kills, right from Matt @ MBE.
Re: Small block race block [Re: jim sciortino] #922068
08/22/11 12:00 AM
08/22/11 12:00 AM
DakFink Offline
DakFink  Offline
That's all fine and Dandy BUT NO-ONE has addressed a readily available Block to screw them on to. Last I looked "out of curiosity" R4's were on the For-Ever waiting list.
Is MBE or PRE making those as well?
Re: Small block race block [Re: DakFink] #922069
08/22/11 12:11 AM
08/22/11 12:11 AM
Dyno
JSL Offline
JSL  Offline
Dyno
DakFink,
I met with Richard Maskin a couple of years ago and dicussed the possibility of producing a block. It was going to be a 2 year/$250,000 dollar project doing it with Dart. I didn't consider it a viable business proposition.
I've been trying to get in contact with Kent Ritter regarding his XR blocks. They look like they are the key to a big cubic inch P5 style motor.
I would love to build a 440-450ci motor to see what it is capable of!
P.S. I have 5 R4/P5 blocks and last I knew there were about 10 in stock at Chrysler/Michigan. Maybe Zippy can update us.
You would struggle getting anything bigger than a 3.625" stroke in the R4 block though. A 4.225" bore hasn't been an issue so far!
Re: Small block race block [Re: JSL] #922070
08/22/11 03:17 AM
08/22/11 03:17 AM
LA360 Offline
LA360  Offline
DakFink,
When Rick Liuzzo was involved with those blocks, he did tell me ordering them with un-machined lifter bores and deck was possible at the time, but they had not tried a P5 head onto them. This was a few years ago and Kent might have looked into this by now.
Alan Jones
Re: Small block race block [Re: JSL] #922071
08/22/11 09:14 AM
08/22/11 09:14 AM
DakFink Offline
DakFink  Offline
That's why I'll stick with my W9-RPs and an R3 block.
If I can't get at least 4.000" stroke (preferably 4.250) I won't mess with it.
