Re: Small block race block
[Re: MattW]
#922054
08/20/11 12:04 PM
08/20/11 12:04 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Ritter told me he can ma nine his blo k to accept the P5 head. Problem is the head itself. They still have water leak issues. I wanted to build a tall deck P5 hemi motor for 10.5 . But no organization would legalize them in my opinion. A gen3 hemi needs alot more head bolts if your going to a max effort program. Maybe we can get Chryslers engineers to look into redesigning the block and heads to a 18 head stud design. Yes right.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
[Re: W8n2DustU]
#922055
08/20/11 01:52 PM
08/20/11 01:52 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
They probably wont because of the advantages of using the head. I mean there is alot more to winning races than the engine, but every little bite helps. As for the G3 extra head bolts i don't think it would be to hard to add the bolts provisions but right now there is no head with the extra bolt soooo. I would like to now if the G3 aluminum block would work with the P5 head.
[Re: W8n2DustU]
#922057
08/20/11 02:36 PM
08/20/11 02:36 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Give Matt at MBE a call about the P-5.
[Re: S/ST 3040]
#922059
08/20/11 06:02 PM
08/20/11 06:02 PM
jim sciortino
Trumbull,CT.
ZIPPY used to keep a post updated with available R-3/R-4 blocks in the "HOT DEALS" section.
The last time I saw it.
........there were some P-5 machined R-4 blocks in stock.
I can't find the post.
I think those don't go big.
Really short deck IIRC.
[Re: S/ST 3040]
#922061
08/20/11 09:33 PM
08/20/11 09:33 PM
Posts: 6,149 Melbourne , Australia
LA360
Aussie Pro Stock runs them at 399 cubes generally. Most of the Aussie Pro Stock blocks run around a 8.7"-9.0" deck. I think the R4's are around 8.8"-8.9" standard. Most comp guys will deck them down as far as 8.4" (which basically starts to cut into the bell housing pattern). AL...
Alan Jones
[Re: LA360]
#922064
08/21/11 12:18 AM
08/21/11 12:18 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Aussie Pro Stock runs them at 399 cubes generally. Most of the Aussie Pro Stock blocks run around a 8.7"-9.0" deck. I think the R4's are around 8.8"-8.9" standard. Most comp guys will deck them down as far as 8.4" (which basically starts to cut into the bell housing pattern). The Aussie heads are an exact copy, right down to the cracks apparently. AL...
I like BOOST!!!
That's not a combo that would want to work very well with Turbos.
And if the heads are prone to leaks/cracks. Turbos would definitely find them.
[Re: LA360]
#922066
08/21/11 11:15 PM
08/21/11 11:15 PM
LA360
I would like to publicly retract the off the cuff comment made about the Aussie P5 heads. I based it on what has turned out to be misinformed information and Con @ PRE (He produces these heads) has been more than willing to show me in person his castings improvements over the factory produced units. I think we sometimes forget that what may consider passing comments can have an negative impact on others to which I apologize. I won't be doing it again!
Alan Jones
[Re: LA360]
#922067
08/21/11 11:36 PM
08/21/11 11:36 PM
jim sciortino
Trumbull,CT.
We've heard the new P-5 kills, right from Matt @ MBE.
[Re: jim sciortino]
#922068
08/22/11 12:00 AM
08/22/11 12:00 AM
DakFink
That's all fine and Dandy BUT NO-ONE has addressed a readily available Block to screw them on to. Last I looked "out of curiosity" R4's were on the For-Ever waiting list.
Is MBE or PRE making those as well?
[Re: DakFink]
#922069
08/22/11 12:11 AM
08/22/11 12:11 AM
Posts: 11 Dyno
JSL
Dyno
DakFink, I met with Richard Maskin a couple of years ago and dicussed the possibility of producing a block. It was going to be a 2 year/$250,000 dollar project doing it with Dart. I didn't consider it a viable business proposition. I've been trying to get in contact with Kent Ritter regarding his XR blocks. They look like they are the key to a big cubic inch P5 style motor. I would love to build a 440-450ci motor to see what it is capable of! P.S. I have 5 R4/P5 blocks and last I knew there were about 10 in stock at Chrysler/Michigan. Maybe Zippy can update us. You would struggle getting anything bigger than a 3.625" stroke in the R4 block though. A 4.225" bore hasn't been an issue so far!
