School me on Open Chamber VS Closed #921933
02/06/11 12:23 AM
02/06/11 12:23 AM
USA
JoesMopar Offline OP
USA
I know that closed chamber heads usually give you the compression and quench that you need/want. But mainly my question is, what is the point of running an open chamber head? It seems to me a closed chamber will do everything you want, so why ever use an open chamber? For example, I can see using it in a later 70's model car where they used lower compression ratios to run on lower octane gas etc....but why were they using them on performance cars in the 60's? Why use them today?
Re: School me on Open Chamber VS Closed [Re: JoesMopar] #921934
02/06/11 12:29 AM
02/06/11 12:29 AM
IN
ahy Offline
ahy  Offline
IN
One reason may be they are not too sensitive to manufacturing variation. Quench depends on precise tolerences. If you can't control deck height very well, for example, the open chamber design is more forgiving. MOPAR block machining in the late 60's/70's wasn't the best.
I believe the open camber head was also part of the emission reduction strategy of the day. Lower NOX perhaps.
Re: School me on Open Chamber VS Closed [Re: ahy] #921935
02/06/11 01:02 AM
02/06/11 01:02 AM
I believe the open camber head was part of the emission reduction strategy of the day. Lower NOX perhaps.
Re: School me on Open Chamber VS Closed [Re: RapidRobert] #921936
02/06/11 01:14 AM
02/06/11 01:14 AM
USA
USA
But I thought a closed chamber would reduce emmissions more because of the more complete combustion?
Re: School me on Open Chamber VS Closed [Re: JoesMopar] #921937
02/06/11 02:22 AM
02/06/11 02:22 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
NOx is the result of high combustion temperature, so having less quench could help towards reducing that.
Re: School me on Open Chamber VS Closed [Re: MowP4rsn] #921938
02/06/11 03:17 AM
02/06/11 03:17 AM
USA
USA
I see, that makes sense. I didn't think they worried about that in the 60's though. So basically the point to open chambered heads is strictly emissions and nothing performance orientated whatsoever.
Re: School me on Open Chamber VS Closed [Re: JoesMopar] #921939
02/06/11 10:26 AM
02/06/11 10:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
EXACTLY , but yes they started to worry about that stuff in the 60's , califorina cars were the first to have air pumps in the late 60's
Re: School me on Open Chamber VS Closed [Re: JohnRR] #921940
02/06/11 12:50 PM
02/06/11 12:50 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
So with that being said, The 10.1-1 compression that was advertised in 69 & 70 on the 383,440's with the 906 heads really wasn't true? More like 9.5-1. Would this be a true fact?
Re: School me on Open Chamber VS Closed [Re: superbeedave] #921941
02/06/11 12:54 PM
02/06/11 12:54 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i measured 8.8:1 on an original 383 magnum motor we pulled out for rebuild.
Re: School me on Open Chamber VS Closed [Re: DJVCuda] #921942
02/06/11 01:11 PM
02/06/11 01:11 PM
Cincinnati, Ohio
Cincinnati, Ohio
Could you imagine that back in 69 you bought a Superbee with a 383 magnum and you were under the impression that it was a true 10.1
engine only to find out it really was 9.0. They probably wouldn't
have sold as many as they did!
Re: School me on Open Chamber VS Closed [Re: superbeedave] #921943
02/06/11 01:40 PM
02/06/11 01:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I can't say for 70 because the piston CH changed but the 68-69 383 HP is about 9.2 as delivered , piston is .0025 in the hole , head is 90 - 92 CC, yes Chrysler OVER RATED compression ratios on the 383 and I am sure others
Re: School me on Open Chamber VS Closed [Re: JohnRR] #921944
02/06/11 10:17 PM
02/06/11 10:17 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
Actually the 69 383Hp engines had a Positive deck. In other words the piston actually was above the block deck surface. I do not have my book in here but I believe the 67 440HP Pistons with the 915 closed chamber heads were at a lower deck than the 1969 and 70 440's with the open chamber heads. I am sure someone will chime in with the numbers. The deck differences is what kept the compression up on the 68/69/70 engines with the open chambered heads. if you punch the numbers into a Compression Calculator (Bore,Stroke, Head volume CC, +/- Effective Dome CC, Deck Clearance, Compressed Gasket thickness, number of cylinders). You will see the factory numbers are real close.
Re: School me on Open Chamber VS Closed [Re: superbeedave] #921945
02/06/11 10:44 PM
02/06/11 10:44 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..Was the manufacturers rating an NHRA limit?
i.e a 383 could be built to 10:1 for competition.
i think 10.5 340's were really around 9.5 if you do the math?
Re: School me on Open Chamber VS Closed [Re: JohnRR] #921946
02/07/11 12:19 AM
02/07/11 12:19 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
EXACTLY , but yes they started to worry about that stuff in the 60's , California cars were the first to have air pumps in the late 60's
But NOT MOPARs sold in California, only the GM and Ford brands.
