Re: HELP! 92 magnum timing chain woes??
[Re: hemibeep]
#921628
02/05/11 06:41 PM
02/05/11 06:41 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I just did one on a 69 340 block. It wouldnt go on unless you pulled back on the tensioner more than just the pin does. It was a tight fit. Took a second hand. IIRC, used a drift in the pin hole and pulled back on it. My Rollmaster chain was pretty darn tight even without it. The tensioner changed the cam timing by one degree. Without tensioner: With tensioner:
[Re: RapidRobert]
#921631
02/06/11 11:48 AM
02/06/11 11:48 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
theres enough oil slinging around you wont need it it will be fine
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
