lets talk six pack carbs. #921540
02/05/11 03:24 PM
02/05/11 03:24 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
I see the 340 & 440 six pack carbs are the same cfm. Can the 340 carbs be used on the 440?
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: lets talk six pack carbs. [Re: stickman] #921541
02/05/11 03:36 PM
02/05/11 03:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes, just a jetting change.
Off topic my buddy finally got that blazer done , he pinched the temp sensor wire and that was what was messing up the trans shifts . Thanks again for the help
Re: lets talk six pack carbs. [Re: stickman] #921542
02/05/11 06:36 PM
02/05/11 06:36 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
the 340 outboard carbs have tabs on the booster to aid in mixture distrubition .
the 440 do not .
i would trade them to someone who needs them for some bb ones .
remove the tab and ruin the value ,
also the metering blocks are different !
Re: lets talk six pack carbs. [Re: calrobb2000] #921543
02/07/11 06:40 AM
02/07/11 06:40 AM
wi
crscuda Offline
crscuda  Offline
wi
hi
Would'nt this be a good thing???
Re: lets talk six pack carbs. [Re: crscuda] #921544
02/07/11 11:07 AM
02/07/11 11:07 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
hi
Only if they are on a 340 manifold. These tabs are there to help make up for a distribution problem in that specific manifold. They might/probably cause issues on any other manifold, such as a 440 version.
