'69 Swinger survivor #921354
02/05/11 12:11 AM
02/05/11 12:11 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
Feb. magazine article on '69 swinger survivor reports owner rebuilt the original 480 cfm carb?
was a '69 swinger 340 carb just 480 cfm?
Re: '69 Swinger survivor [Re: can.al] #921355
02/05/11 01:15 AM
02/05/11 01:15 AM
It'd be an AVS. A guy (on here) posted CFM's for AFB's which may have the same flow #'s as the same sized AVS's & 1&1/8 pri/1&1/4 sec is 400 CFM. 1&3/16 pri/1&1/4 sec is 500 CFM. Haven't visually compared the clusters/venturi's/throttle shafts/blades etc (That which would affect flow) etc between an OE AFB/AVS but I'd say good chance they are the same. Dont have an AVS to side by side check the air valve assy
Re: '69 Swinger survivor [Re: RapidRobert] #921356
02/05/11 01:38 AM
02/05/11 01:38 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
They were supposed to be 625's, but Carter never went by CFMs on the OEM stuff.
Re: '69 Swinger survivor [Re: can.al] #921357
02/05/11 02:04 AM
02/05/11 02:04 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Where Holley used 1.5 pressure drop for rating 4bbls. and 3.0 for 2bbls, (I think Carter followed suit) Chrysler used 2.0 for everything which resulted in some pretty low ratings for 4bbls, IIRC this minutia. If I'm wrong somebody with a better memory will be along soon.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
