BB Abody fenderwell header pics
#921204
02/04/11 07:34 PM
02/04/11 07:34 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Does anyone have pictures of a bigblock in their A body with hooker super comps? I need a rough idea of where to cut the holes. Its a 69 dart with a 440 if that helps. Thanks, Chris.
Re: BB Abody fenderwell header pics
[Re: challengermike]
#921206
02/04/11 07:45 PM
02/04/11 07:45 PM
RapidRobert
Mike what size tires are you running and did you have any rubbing?
#921207
02/04/11 07:48 PM
02/04/11 07:48 PM
69B3GT
Mira Loma, CA
If you go on there website your can print the directions and it gives you the measurements of where to cut.However i had to cut mine way bigger to get them to fit.
Thank you Ill do that now
[Re: RapidRobert]
#921209
02/05/11 01:33 AM
02/05/11 01:33 AM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
Im just putting the car together now and i still have to do the rear end.Im probably going with a minitub and relocating the springs inward.I plan on running 275/60/15 drag radials.
