Re: 1970 Radios?
[Re: VitaminCRunner]
#921110
02/04/11 05:54 PM
02/04/11 05:54 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Found a Cuda AM/FM but its way different than B-body. How much do the 70 B Body AM / FM's go for?
A lot , one year only radio
Re: 1970 Radios?
[Re: JohnRR]
#921111
02/04/11 06:08 PM
02/04/11 06:08 PM
Posts: 18,157 Mass
DAYCLONA
Mass
X2......They usually start at $500 and go up depending on condition/completeness/working condition
Re: 1970 Radios?
[Re: BigMoneyLewis]
#921120
02/06/11 04:18 PM
02/06/11 04:18 PM
Posts: 1,177 People's Republic of Kali
70runner
By the way, the radio pictured above does not have the correct push buttons. It looks like someone swapped the tuner mechanism, buttons and all , with an A body unit.
Greg
By the way, there was no swap of any "tuner mechanism, buttons, and all". This is a mint 70B body am/fm out of a survivor 70 Sport Satellite. The buttons are original to the radio.
Re: 1970 Radios?
[Re: missu34]
#921123
02/06/11 09:57 PM
02/06/11 09:57 PM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
The incorrect buttons are in fact A body pieces, as you can tell from the shape . The B is more square and slightly textured at the very tip. A body is more smooth, rounded edges . IF , and it's a very big IF , the above radio came from the assembly plant with those buttons, it would be because they ran out of the correct ones, and it would be the only one I have ever seen (and I have handled at least 175-200 1970 B body radios in this shop) By the way, Their were 2 diffrent vendors for the 1970 B body radios (Bendix and Phillips) 3 diffrent buttons for the 70 B , and all 3 buttons have the squares facing up . I have seen a couple cases where some dork took his buttons off and tried to turn them over , but that's another story.
Greg
Re: 1970 Radios?
[Re: missu34]
#921124
02/06/11 10:09 PM
02/06/11 10:09 PM
BigMoneyLewis
Alabama
While were on this subject can any id these by part #
2884128
2884759
No problem .
2884128 is 1969 Dodge Polara and Monaco AM
2884759 is 1970-71 E body AM (chrome buttons)as well as 1972-74 (black buttons)
Greg
