Rear main seal installation question ??? #920281
02/03/11 02:03 PM
02/03/11 02:03 PM
Penna
70satelliteguy Offline OP
Penna
Do I install it with the high lip facing(closest to) the crankshaft or facing the back of the block? Any other installation suggestions?
Thanks Mike
Re: Rear main seal installation question ??? [Re: 70satelliteguy] #920282
02/03/11 02:15 PM
02/03/11 02:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The sharp edge of the lip goes toward the engine. That way when the oil hits the seal it will be pushed away from the crank not directed along it to the outside.
Re: Rear main seal installation question ??? [Re: stumpy] #920283
02/03/11 02:39 PM
02/03/11 02:39 PM
Penna
Penna
Thanks Stumpy, any more installation recommendations???
Mike
Re: Rear main seal installation question ??? [Re: 70satelliteguy] #920284
02/03/11 02:52 PM
02/03/11 02:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
lip toward oil so that any internal force from oil pan will push the lip out against the sealing surface. The other way the oil would push down on the outer tapered surface and push the sealing surface away.
Re: Rear main seal installation question ??? [Re: 70satelliteguy] #920285
02/04/11 08:11 PM
02/04/11 08:11 PM
Fitchburg, WI
BIGHOOK Offline
BIGHOOK  Offline
Fitchburg, WI
Mike
Apply a small dab of Hi-Temp RTV sealer at the ends of the seal half on the main bearing cap. Just a little additional cheap insurance against any future oil leaks.
Re: Rear main seal installation question ??? [Re: 70satelliteguy] #920286
02/04/11 09:58 PM
02/04/11 09:58 PM
Anybody have any opinion on smoothing the crank serrations when using this seal rather than the rope that was OE. I would have your shop take .010" off of the retainer in their rod cap grinder
Re: Rear main seal installation question ??? [Re: RapidRobert] #920287
02/04/11 10:53 PM
02/04/11 10:53 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I've never done anything with the crank serrations on the 4 engines I've put together, none of them had any leak from there.
Re: Rear main seal installation question ??? [Re: RapidRobert] #920288
02/04/11 10:54 PM
02/04/11 10:54 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
I have not had much rear main seal luck with big blocks in the last couple years. Stock retainer and 3 different seals, all leaked. Thinking maybe the crank but it shouldn't leak as bad as it did with a few thou taken off the seal surface. Then my dad had a beeotch of a time with a stock 383, leaked like crazy. Never had problems until the last 2 years or so. Mine leaks just a little but that is still too much for me.........I'm sick of changing rear mains though so I live with it for now. Doing this twice on the floor inside of 50 miles of putting the new engine in gets a bit tiring.
