b body disc. brake conversion kit #920076
02/03/11 01:39 AM
02/03/11 01:39 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
has anybody used this kit, i have a 68 dodge coronet with drum brakes looking to convert to front disc., this kit is very affordable
63 74 Charger Belvedere GTX Brake Conversion Kit NEW
item # 140508356913 on ebay
thanks
Randy
Re: b body disc. brake conversion kit [Re: cornet684me] #920077
02/03/11 02:16 AM
02/03/11 02:16 AM
Backwoods of NC
Topher Offline
Topher  Offline
Backwoods of NC
I don't see hoses, or a proportioning valve. If you have a pull your own part junk yard in your area, I suggest going there and seing if you can get all the stuff from a car there: master cylinder(and booster), prop. valve, lines and front hoses(for making sure it will work to match new ones), spindles and everything else. New rotors/bearings/calipers/pads are affordable enough that I believe you'll still be less than the price of that kit. Who knows, you may get lucky and find one that just had all that replaced. I installed spindles from an 88 Diplomat on a friend's 66 Coronet several years ago.
Topher
topher@headlightmotorman.com
www.headlightmotorman.com
67 Charger 383 3 pedal car
[|||||||||o|||||||||]
Re: b body disc. brake conversion kit [Re: cornet684me] #920078
02/03/11 11:02 AM
02/03/11 11:02 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
See MA Disc Swap Tech
Careful using F/J/M/R/Late-B knuckles...they are taller and increase bumpsteer.
Rick
Re: b body disc. brake conversion kit [Re: cornet684me] #920079
02/03/11 11:34 AM
02/03/11 11:34 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Someone had spindles and caliper brackets in the swapmeet area on here last month. Rotors and calipers are cheap from Advance Auto, etc.. Likewise with bearings, seals and hoses. Ehrenberg even has reasonably priced new master cylinders on here. The prop valve would be about $40 from Summit. I'd piece it together (I did !!).
Re: b body disc. brake conversion kit [Re: Rick_Ehrenberg] #920080
02/03/11 12:53 PM
02/03/11 12:53 PM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Rick, Very interesting reading. I'm dealing with a '69 b-body, also,
but mine had a MPB disc conversion done by the former owner.
The aftermarket kits should have all the bugs worked out. The brakes
don't work bad stopping the car, although I don't think the rear
drums are working. I was interested in the steering 'abnormalities'
you stated from mixing the wrong parts.
Although I have paperwork from the former owner showing alignment
being done and a rebuilt steering box from Steer and Gear, the
car handles poorly especially on secondary roads. Any input on this
system, anyone?
Re: b body disc. brake conversion kit [Re: demonH1B] #920081
02/03/11 01:44 PM
02/03/11 01:44 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
system, anyone?
You're really not giving enough information to give any sort of accurate response. So a few words.
Just because there is an aftermarket kit doesn't mean that it's what YOU need, or anyone else for that matter;
look at the poor handling characteristics of some of these high dollar front suspension swaps and judge for yourself.
Having a new steering box is a start, but there are a lot of other potential weak links in the chain between the box
and the pavement.
A standard alignment only measures a few fields and tells you nothing about what your suspension is doing as it goes
through it's range of travel - what about bump steer?
Besides, what numbers are they using for aligning the car? Ones from 1969 that were set by antiquated standards
and for bias-ply tires?
If you want the car to handle well, it can happen but you're going to have to do some homework and make a few choices about how
it is that YOU would like the car to handle. This will guide what parts you use and how the setup is configured.
I'm tempted to tell you to take the car to a race chassis shop and have them go over the front end but if you don't know a little
going in it may just be a waste of money for you.
Re: b body disc. brake conversion kit [Re: Montclaire] #920082
02/03/11 02:41 PM
02/03/11 02:41 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I personally dont know why people worry about installing rear disks, Have the rear drums ever proven inadequate? And the front brakes do 70 percent of the stopping anyway.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: b body disc. brake conversion kit [Re: HemiRick] #920083
02/03/11 04:08 PM
02/03/11 04:08 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Rear disc brakes:
1. Look cool
2. Lighter than drums
3. Less likely to turn mushy when overheated
Most people will never feel the difference on daily drivers, however.
Re: b body disc. brake conversion kit [Re: DoctorDiff] #920084
02/03/11 04:32 PM
02/03/11 04:32 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I guess the advantage would be less unsprung weight but I wouldn't go out of my way to install them. The drums will do the job just fine.
Re: b body disc. brake conversion kit [Re: Rick_Ehrenberg] #920085
02/03/11 04:38 PM
02/03/11 04:38 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
Rick
and you might notice that bump steer if you are Richard Pretty.Preachin to the choir...again and again... http://www.moparmusclemagazine.com/techa...dles/index.html
Re: b body disc. brake conversion kit [Re: 70RT Charger] #920086
02/03/11 05:00 PM
02/03/11 05:00 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
The later spindles are a less than ideal option. Why would you use them when you can source the proper ones
or buy repops from master power?
Eberg has always cautioned against the later pieces, and Mopar Muscle has, IMO, downplayed the effect of such
a swap to save face after recommending they be used.
Using the larger spindles would cause problems with stock/original ball joints. Newer joints have an increased range
of motion but they are at their max with these. With all of the manufacturing issues, who is to say that the chinese
will continue to add in this extra wiggle room or build a ball joint to the specs required to live with these spindles,
specs that have nothing to do with a factory application?
We have had some long, thoughtful, and numbers packed threads about this but moparts mods would never adopt
them into the tech section, so they've all be lost to time. Take a look at the camber and roll center figures in the mm link,
they say quite a bit.
Get the right parts and be done with it. Who solves a problem with a new one? One major rule that I always try to
follow with cars is that anyone off the street should have confidence that the car should operate predictably
should they wind up driving it.
Re: b body disc. brake conversion kit [Re: Montclaire] #920087
02/03/11 05:35 PM
02/03/11 05:35 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
By the way, something that I am not seeing in the MM link, that was in the original article, was that the inital
specs were not set to a stock mopar, but rather had two changes. One was ride height, I don't recall the other.
The reason I mention this is that is could potentially skew the results in favor of, or minimizing, differences between
the spindles. Since the numbers were wrong from the get-go, all the recorded 'data' did was fuel further speculation.
In any event, Chrysler Co engineers didn't just pick a design out of a hat, AND they continued to produce BOTH sets
of spindles at the same time. If it were ok to use the later spindles, don't you think they would have simply made them THE
spindle on all production cars?
What is laughable is that the MM crew has even gone so far as to suggest that these spindles may be an IMPROVEMENT!
As I have proved beyond doubt in the past on this board, MM will pass on any tech 'article' submitted to them as gospel
but will not stand behind what they print. You can't have it both ways, boys. They won't tell you to take their articles with
a grain of salt, but I will. FYI
Re: b body disc. brake conversion kit [Re: Montclaire] #920088
02/03/11 08:30 PM
02/03/11 08:30 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Exactly. This has always been my point. If the spindles are interchangeable, why would Chrysler have gone to the trouble and expense to produce a new design?
It's Swifty! Swifty, you toad sucker!
Re: b body disc. brake conversion kit [Re: zrxkawboy] #920089
02/03/11 11:21 PM
02/03/11 11:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
As often as this topic has come up I can't recall this point ever having been made in the past. Either way, it is absolutely THE best defence ever! Well put!
Re: b body disc. brake conversion kit [Re: Stanton] #920090
02/04/11 12:13 AM
02/04/11 12:13 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Hey, check it out. www.resto-modtechnology.com b-body disc brake kits for $396.00 sku # is swbks6374
Re: b body disc. brake conversion kit [Re: 6PACMAC] #920091
02/04/11 12:31 AM
02/04/11 12:31 AM
Mansfield,Ohio
moparrulzzz Offline
moparrulzzz  Offline
Mansfield,Ohio
I know this is off topic but I am still looking for verification that I can forward hang the calipers on my '68 Coronet with a OEM sway bar with no caliper to sway bar contact by shortening the the sway bar links!!
Re: b body disc. brake conversion kit [Re: Rick_Ehrenberg] #920092
02/04/11 08:53 PM
02/04/11 08:53 PM
Brandon, Ms
Brandon, Ms
thanks for the web site, that will help out alot
Re: b body disc. brake conversion kit [Re: cornet684me] #920093
02/04/11 08:59 PM
02/04/11 08:59 PM
Brandon, Ms
Brandon, Ms
thanks for all the input from everybody, this will shed some light on what i have to look forward to
Re: b body disc. brake conversion kit [Re: DoctorDiff] #920094
02/23/11 10:27 PM
02/23/11 10:27 PM
Marlboro, NY, USA
Marlboro, NY, USA
Rear disc brakes:
1. Look cool
Guess I'm a bit late to this party, sorry (I'm jammed right now). Another big advantage to 4-wheel discs: You lose the Bendix Duo-Servo rears, which are notoriously hard to modulate under near-lockup conditions. With Duo-Servo drums on the rear -- which have wildly varying, nonlinear, line pressure requirements -- correct F/R proportioning (crucial to short stopping distances) is a constantly-moving target.
On the tall knuckle deal, 2 quick points:
> By actual measure, the bumpsteer is tripled if you use this to replace the standard knuckle. (The longer design was specifically needed on '73-up Bs, and F/J/Ms, because the UCA mount had to move up when the K became rubber isolated.
> Warning: Some repops are CAST IRON. I have heard (from vendors!) of wrecks because of catastrophic failures.
Rick Ehrenberg
Re: b body disc. brake conversion kit [Re: Rick_Ehrenberg] #920095
02/23/11 11:42 PM
02/23/11 11:42 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I ended up with the SSBC kit.It used my exsisting spindles and have very nice 4 piston calipers.Sure,there are upgrades to aluminum calipers or crossdrilled & slotted rotors,but did not up grade.EVERYTHING was in the kit right down to cotter pins,hoses & prop valve No problem stopping over 3800lbs at 135 MPH in the 1/4 mile.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
