steering column mods #920031
02/03/11 12:49 AM
02/03/11 12:49 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
im trying to take apart my column in the pic im trying to take off the piece that is in the right of the pic, it has a bearing pressed onto the shaft any ideas?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: steering column mods [Re: Stroker Scamp] #920032
02/03/11 01:15 AM
02/03/11 01:15 AM
Out West
408strokerdart Offline
Out West
It has threaded holes for a puller right? IIRC there is a snap ring holding it's place on the shaft. Remove the snap ring and use a puller. I might be wrong, but I think it is that easy.
Re: steering column mods [Re: Stroker Scamp] #920033
02/03/11 01:43 AM
02/03/11 01:43 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Pull the snap ring....it's there but not in the diagram..at the middle of the shaft next to the bearing.
Re: steering column mods [Re: Sixpak] #920034
02/03/11 04:17 AM
02/03/11 04:17 AM
pacific northwest
pacific northwest
thanks guys heres what im doing
Re: steering column mods [Re: Stroker Scamp] #920035
02/03/11 04:18 AM
02/03/11 04:18 AM
pacific northwest
pacific northwest
2
Re: steering column mods [Re: Stroker Scamp] #920036
02/03/11 09:15 AM
02/03/11 09:15 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Looking good. What did you fill the hole with?
Re: steering column mods [Re: RacerGofKGB] #920037
02/03/11 08:57 PM
02/03/11 08:57 PM
pacific northwest
pacific northwest
well since i dont use the column shift anymore i decided to shave down the gear indicater i just cut off the material and ground it smooth. took out the column shift rod to save a couple pounds
Re: steering column mods [Re: RacerGofKGB] #920038
02/03/11 09:23 PM
02/03/11 09:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can use JB Weld to fill any holes
