lightweight working headlights #919934
02/02/11 10:24 PM
02/02/11 10:24 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
I have seen these in some old cars at the track. Never have figured where to get them. I need a pair for my 65' barracuda and want street legal stuff. The glass ones are heavy.
Re: lightweight working headlights [Re: Leon441] #919935
02/02/11 10:28 PM
02/02/11 10:28 PM
Fredericksburg,Virginia
1 Bad Duster Offline
I would like to know this also..
1973 Pro Street Duster
Re: lightweight working headlights [Re: Leon441] #919936
02/02/11 10:28 PM
02/02/11 10:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look for the halogen ones with the screw in bulb
from the rear... your gonna have to buy the plastic
headlight like your current ones
Re: lightweight working headlights [Re: MR_P_BODY] #919937
02/02/11 10:41 PM
02/02/11 10:41 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Check out Daniel Stern he is a Mopar guy and is a lighting guru.
http://www.danielsternlighting.com/
Re: lightweight working headlights [Re: PHJ426] #919938
02/03/11 01:05 AM
02/03/11 01:05 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Leon, I bought a '85 Daytona a few years ago that had the 4 head light front end and one of the head lights was made out of plastic. It didn't weigh hardly anything and was a sealed beam. I think I still have it. If I can find it tomorrow I'll let you know who made it. I'm thinking it was Wagner, just not sure.
Brian Dunnigan
Re: lightweight working headlights [Re: MR_P_BODY] #919939
02/03/11 05:24 AM
02/03/11 05:24 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
H-4 headlights.
Some motorcycle stuff is plastic.
Re: lightweight working headlights [Re: autoxcuda] #919940
02/03/11 05:40 AM
02/03/11 05:40 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: lightweight working headlights [Re: StripeHOG] #919941
02/03/11 10:46 AM
02/03/11 10:46 AM
Finland
mafo Offline
mafo  Offline
Finland
I need one pair also if you can find any
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: lightweight working headlights [Re: mafo] #919942
02/03/11 11:39 AM
02/03/11 11:39 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I'd be up for a pair also.......
If you can't handle the truth, you're living a lie.......
Re: lightweight working headlights [Re: Leon441] #919943
02/03/11 12:07 PM
02/03/11 12:07 PM
Kentucky
jbsperformance Offline
Kentucky
Here's some too. Pilot makes them. They are all made of plastic.
http://www.yearone.com/serverfiles/headline.asp?hid=126DP9966
Re: lightweight working headlights [Re: jbsperformance] #919944
02/03/11 12:41 PM
02/03/11 12:41 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
How much weight can be saved?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: lightweight working headlights [Re: BloFish] #919945
02/03/11 12:54 PM
02/03/11 12:54 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The new JEGS catalog has them in it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: lightweight working headlights [Re: jbsperformance] #919946
02/03/11 01:27 PM
02/03/11 01:27 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
they are pretty cool!!
Re: lightweight working headlights [Re: sixpackgut] #919947
02/03/11 01:37 PM
02/03/11 01:37 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
So what kind of weight savings are they compared to glass
Anyone know AMP draw, could the stock switch be used
Re: lightweight working headlights [Re: sjs64polara] #919948
02/03/11 01:41 PM
02/03/11 01:41 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
in the description it says to use a relay. you should use a relay anyway though. i would like to know how much a 7" glass light weighs also. i will post later if no one else can weigh one
Re: lightweight working headlights [Re: sixpackgut] #919949
02/03/11 02:58 PM
02/03/11 02:58 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: lightweight working headlights [Re: 1967dartgt] #919950
02/04/11 01:20 AM
02/04/11 01:20 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I have the ones from Jegs, It is lighter but I think the front is still glass while the back is plastic.
I'll try to take one out tomorrow and compair the two
Re: lightweight working headlights [Re: SB412DUSTER] #919951
02/04/11 11:01 AM
02/04/11 11:01 AM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
Got this from AUTO-ZONE's web page
Pilot Automotive/2 pcs. 5 3/4 in. round headlamp conversion kit for 5006 headlamp
Part Number: WI-HL4
Weight: 2.0 lbs
Shipping Information: Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
Re: lightweight working headlights [Re: sjs64polara] #919952
02/04/11 11:20 AM
02/04/11 11:20 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I put the 7" ones from Jegs. Dont know how much they weigh but they are bright and make the guy at the ticket shack look the othe way
Re: lightweight working headlights [Re: poisondart2] #919953
02/04/11 03:52 PM
02/04/11 03:52 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Chad's Buick has the 4 square headlights. The glass ones are about 3.5lbs each. The plastic ones are less than .5lb. That's a 12lb savings. Ours are wagner, but they no longer make them and we bought every one that NAPA had in their system, at least that style.
Monte
