Another What cam is it? #919702
02/02/11 04:06 PM
02/02/11 04:06 PM
NW Minnesota
Maximus_Wedges Offline OP
NW Minnesota
I got a big roller with a set of Brewer heads I just purchaced. I need to stick it in my mock up block and run a dial over it when I get a chance. On the end of the cam Numbers are 83472 86446 H 111
Going around the cam by the dist. drive 689566 042302 is there something to de code here? Thanks in advance guys.
Re: Another What cam is it? [Re: Maximus_Wedges] #919703
02/03/11 12:42 AM
02/03/11 12:42 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
@ 0.050
283 with a .472 lobe intake
286 with a .446 lobe exhaust
111 CL
How's that for a guess? lol
8.30's @3400 lbs
Re: Another What cam is it? [Re: Mike Swann] #919704
02/03/11 09:28 AM
02/03/11 09:28 AM
NW Minnesota
NW Minnesota
I'll bet your guess is a good one Mike.
Duration sounds about right and @ 1.7 lift would be .802 int. and .758 ex.
Re: Another What cam is it? [Re: Maximus_Wedges] #919705
02/03/11 10:10 AM
02/03/11 10:10 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
The other numbers ID the core and mfg date. Get the degree wheel out.
8.30's @3400 lbs
