To lock out my distributor or not? Mallory unit #919691
02/02/11 02:42 PM
02/02/11 02:42 PM
St. Clair Shores, Michigan
bigsbigelow Offline OP
I have a Mallory built MP vacuum advance distributor in my 340. I want to re-curve it this off season as out of the box it has a huge total advance sweep of 28 degrees. I am looking into buying the Mallory kit that comes with springs and a set of advance limit gauges. I plan on installing a NOS Sniper system either this season or next and was recommended to lock my timing in at 20 degrees while on the spray. The motor is 10.5:1 compression with iron heads and runs on pump 93. Should I just go ahead and lock my timing in now or wait until I get the kit? If I lock it out, could I have issues with detonation? I just want some insight. I could just experiment with it but can't drive it here in Michigan for a couple of months so figured I would ask.
P.S. Here is my cam spec if it helps any cam spec
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: To lock out my distributor or not? [Re: bigsbigelow] #919692
02/02/11 05:10 PM
02/02/11 05:10 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
recommended to lock my timing in at 20 degrees while on the spray .
at 20 without your car will be a pig.when not spraying
home of the
Sox and Martin Hemi Duster
Re: To lock out my distributor or not? [Re: HEMIFRED] #919693
02/02/11 05:20 PM
02/02/11 05:20 PM
Correct, I would be adjusting the timing at the race track when I use the kit. Probably will get a MSD timing control and 6AL when I get the kit so I can adjust the timing a little easier.
Maybe just get one of these even Mallory Hyfire
Re: To lock out my distributor or not? Mallory unit [Re: bigsbigelow] #919694
02/02/11 05:59 PM
02/02/11 05:59 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
if you are considering adding any type contoller
I would wait until I decided to add the spray.
With technology advancing so quickly these days it might be advantageous
home of the
