Post deleted by moparts
#919638
02/02/11 02:14 PM
02/02/11 02:14 PM
Re: 70 440 car vs truck motor
#919640
02/02/11 02:18 PM
02/02/11 02:18 PM
Posts: 4,848 Memphis
HemiRick
Memphis
That MH motor will work fine in a car no significant differences.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#919641
02/02/11 02:31 PM
02/02/11 02:31 PM
#919642
02/02/11 02:43 PM
02/02/11 02:43 PM
Posts: 1,323 La Grange, Ky
70rrclone
La Grange, Ky
i just finished installing a 77 440/727 out of a 33ft titan mh in my 70 satellite. all the i had to do for the engine was change the motor mounts, oil pan and manifolds. for the trans i swapped output shaft and the tail housing. got the right driveshaft from Tony's . i have been driving it the last few days and have had no issues. i didnt build it though it was very clean and only had 50K on it.
[Re: 70rrclone]
#919643
02/02/11 03:22 PM
02/02/11 03:22 PM
[Re: 70gtx440dana]
#919646
02/02/11 04:15 PM
02/02/11 04:15 PM
[Re: 70gtx440dana]
#919649
02/02/11 05:08 PM
02/02/11 05:08 PM
#919650
02/02/11 07:07 PM
02/02/11 07:07 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I am not going to focus on correct internals. I do want it externally correct as possible. I just want to freshen it up with existing internals. Since I am doing this I will most likely use a 727 that is currently behind a 69 383. Can I use the stock converter that is on this trans. or do I need a 70 style?? I need one more schooling on the internal/external balance issue. 70 is when they changed it correct? I am just trying to avoid future problems with vibrations. Could I simply use the converter from the trans. that is currently on the 440? Or use the complete trans if it has the long tail shaft? I don't have enough experience on pans so I better got the 6 quart and tube from Ma Mopar. I assume it will look fairly correct?
Yes, 70-71 440 HP and 6-pk got internally balanced due to teh heavy rods.
Assuming it's not been cobbled over teh years, a motorhome trans will have an external parking brake and will be a short-tail. No good for car use.
If this 70 engine is internally-balanced any 67-newer 'internal-balanced' 727 converter will work. Sounds like either teh MH or the 69 converter should be OK. Whether it will give a desirable stall speed is another matter.
[Re: Fury Fan]
#919651
02/02/11 07:21 PM
02/02/11 07:21 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
Yes, 70-71 440 HP and 6-pk got EXTERNALLY balanced due to the heavy rods.
Assuming it's not been cobbled over the years, a motorhome trans will have an external parking brake and will be a short-tail. No good for car use.
If this 70 engine is internally-balanced any 67-newer 'internal-balanced' 727 converter will work. Sounds like either the MH or the 69 converter should be OK. Whether it will give a desirable stall speed is another matter.
Fixed
[Re: Fury Fan]
#919652
02/02/11 07:21 PM
02/02/11 07:21 PM
#919653
02/02/11 07:25 PM
02/02/11 07:25 PM
JohnRR
Good deal. I have heard of some 70's truck motors that have the six pack rods and crank. I don't know if there is any truth to it? I guess I will find out on teardown. As far as the trans goes, should I just scrap it or one of the other posts said he changed out the tail shaft and housing and used the trans. What are the last three on the six pack rods so I can check them. I am not concerned with stall speeds. Not after performance. Just want a nice reliable drivetrain.
You can swap the mainshaft and the tail off a smallblock car trans and throw a shift kit in it and be good to go , go thru it while it's apart. Buy a Hi stall factory refurbed convertor from Dayco , they are about 75 plus your core .
#919654
02/02/11 07:29 PM
02/02/11 07:29 PM
JohnRR
Just saw this , ignore my post above , use the 69 383 trans and convertor ... assuming it's an internal balance engine , if it's external just buy the B+M weighted flexplate and use the 383 convertor ... the 70 440 in HP trim used the 6qt Hemi pan.
[Re: JohnRR]
#919656
02/03/11 01:40 PM
02/03/11 01:40 PM
Fury Fan
Indiana
Fixed
Thanks, JohnRR, I re-read it a few times while I was typing it and still missed it.
[Re: Fury Fan]
#919657
02/03/11 02:04 PM
02/03/11 02:04 PM
