Re: Power valves
[Re: Kirby]
#91956
07/21/08 03:16 PM
07/21/08 03:16 PM
I don't know how things are these days but back when I had my hands into a Holley several days of the week, here's what fails them in no particular order.
FIRST I've found many leaky right out of the box. This (back then) used to include several brands and carb kits as well as Holley originals
SECOND Backfireing (cold start, retarded timing, etc) back through the carb
THIRD Wrong/ bad gasket
FOURTH Overtorquing the valve can damage it
The valve you need has nothing to do with blowing it out. It has to do with when the valve opens compared to intake vacuum.
Also, how do you know for sure that "you are blowing it out?"
Re: Power valves
[Re: Kirby]
#91960
07/24/08 10:49 AM
07/24/08 10:49 AM
Posts: 3,905 Minnesota
3twos
Minnesota
Usually only a backfire wrecks the powervalve.Have you checked the float level? Once in while the car will run well when it's cold and when it is hot and idling the bowl level gets too high and makes the engine load up and it seems like a bad power valve.Check the vacumn in gear if it's an auto and get the correct valve.
Al & Sheila
Re: Power valves
[Re: 3twos]
#91961
07/24/08 11:16 AM
07/24/08 11:16 AM
also, (and this seems weird) Ive noticed that if the bowl screws are titghtened up real good, the carb runs bad- likes its rich. my bowl screw heads are all messed up from retorquing them over the years- but it works for me
Re: Power valves
#91962
07/24/08 01:17 PM
07/24/08 01:17 PM
RapidRobert
1/2 of your manifold vacuum reading at idle in gear for auto or in neutral for stick for a PV size is a good start.
