Re: Colors on Rear Panel on Gtx
[Re: gtx6970]
#919073
02/02/11 12:57 PM
02/02/11 12:57 PM
Posts: 1,060 Ball Ground GA
TrueTripleX
Ball Ground GA
light textured arget on the outer perimeter. dark red on the 2 inner pinstipe areas , then a real low gloss black in the 2 larger depressions. I've had 2 NOS panels and I don't think either on had flat black in those areas
[Re: MONC]
#919074
02/02/11 02:28 PM
02/02/11 02:28 PM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
Is't there a technical bulletin as to the paint code . Thought the back panel was Organisol...
Organsol has a texture,The black in a 1969 GTX panel is smooth .
I've owned 4 1969 GTX's and 2 NOS rear panels ( all now gone ) and not one of them has ever had any texture to the black
[Re: MONC]
#919076
02/02/11 06:52 PM
02/02/11 06:52 PM
gtx6970
It's a dry heat
Sorry, was thinking 70 not 69, sorry for the confusion.. carry on...
All is good.
I've never owned a 70 so you could be right on that one
