rear spring relocation #918793
02/01/11 03:27 PM
02/01/11 03:27 PM
nebraska
roadrunner470 Offline OP
nebraska
Wondering if anybody has a description or pictures of how it is best done. I have the mopar performance kit and will be using caltracs with their monoleaf springs.
Re: rear spring relocation [Re: roadrunner470] #918794
02/01/11 04:05 PM
02/01/11 04:05 PM
What year and body style are you wanting to use the kit on?
Re: rear spring relocation [Re: Cab_Burge] #918795
02/01/11 04:23 PM
02/01/11 04:23 PM
nebraska
nebraska
72 roadrunner sorry that slipped my mind
Re: rear spring relocation [Re: roadrunner470] #918796
02/01/11 09:56 PM
02/01/11 09:56 PM
FL
74-440Charger Offline
FL
I'm considering the same for a 74 Charger.
Re: rear spring relocation [Re: 74-440Charger] #918797
02/01/11 10:43 PM
02/01/11 10:43 PM
Truckville, the capital of NY
85_Ram_4speed Offline
These were from a '71 Charger I did last year for a friend. Currently doing a '74 Road runner for someone else. Hope they help.
Front spring box:
You can just make out the rear shackle here:
Outcast Dodge guy.
Re: rear spring relocation [Re: 85_Ram_4speed] #918798
02/01/11 11:20 PM
02/01/11 11:20 PM
nebraska
nebraska
How do you go about locating the holes for the front spring hanger? The back one i assume is second and you just line stuff up from the spring with the desired shackle angle.
Re: rear spring relocation [Re: roadrunner470] #918799
02/02/11 12:30 AM
02/02/11 12:30 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
there is a build on this at bigblockdart.com that i used, sorry dont know how to link it
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: rear spring relocation [Re: roadrunner470] #918800
02/02/11 12:48 AM
02/02/11 12:48 AM
if your looking to get the most tire clearances from the relocation, mount the front spring box outer side to the inside of the outer sub frame rail, don't center it I'm not familar with the rear spring hangars on that year B body, do they unbolt? If they do you may be able to cut a V in the rear sub frame and weld that hangar into the sub frame. See the picture attatched to see what I'm talking about. For locating the front spring bolt location see if you can buy or borrow a machinests transfer or center punch the same diameter as the bolt. remove the leaf spring and leave the stock hangar in place, slide the center punch(transfer punch) in an bang it into the rear sub frame, use that as your locating marks, do both left and right sides the trick is finding a 90 degree drill motor and short enough drill bits to use in that location after marking the location Greenlee makes chassis punches in a lot of different sizes that work excellent, there a little spendy for one or two times use but they cut a very precise hole, they do require a pilot hole to start with
Re: rear spring relocation [Re: Cab_Burge] #918801
02/06/11 09:51 PM
02/06/11 09:51 PM
nebraska
nebraska
Thanks for the replies. I will call the welding supply place tommorow, but where else would you go about getting a machinist transfer or a big center punch?
Re: rear spring relocation [Re: roadrunner470] #918802
02/06/11 10:53 PM
02/06/11 10:53 PM
Find out what size the front spring bolt is, 1/2,9/16 or ? whay ever size it is and then call some of the local machine shops and ask them if you can rent one of there center punches or transfer punch. If they won't rent you one or loan it out ask if they will take a grade eight bolt that you furnish (make sure the bolt is long enough to go through the front spring hangar and touch the frame) and turn the threaded end down to make a center punch out of that bolt
