Page 1 of 4 1 2 3 4
440 Source Stealth Heads #918345
01/31/11 10:53 PM
01/31/11 10:53 PM
USA
JoesMopar Offline OP
USA
Would these heads be good on a mild 383? I'm thinking KB flat tops, XE274 cam, stock rockers, Performer RPM intake and headers. Originally I was wanting to do a budget build, but I might want to get these if anything to use on another project at some point. I want to use the parts I listed to keep my budget in check. I just thought I was going to have to spend money to have the 906's rebuilt anyway so I might as well get something I can use somewhere else if I want.
Would anyone also know what my Compression Ratio would be? Not sure of the head gasket thickness yet, and as far as I know it will have a stock deck height (if anyone could recommend a measurement to mill the block would help). Thanks
Re: 440 Source Stealth Heads [Re: JoesMopar] #918346
01/31/11 11:58 PM
01/31/11 11:58 PM
been considering a set myself & guys (on here) have opinionated that the best way to go is to have em CNC ported and to have the valve job/valves etc checked over well. The alum wicks off heat so you would need higher CR. Nothing real specific here but wanted to give you a btt bump
Re: 440 Source Stealth Heads [Re: RapidRobert] #918347
02/01/11 12:00 AM
02/01/11 12:00 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
....x 2 .. A LOT higher CR.
Re: 440 Source Stealth Heads [Re: dOOc] #918348
02/01/11 01:32 AM
02/01/11 01:32 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
its general rule to build a motor w 1 point higher comp w alum heads.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 440 Source Stealth Heads [Re: dOOc] #918349
02/01/11 02:30 AM
02/01/11 02:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
On a mild build they should be good without porting.I have them on my 440 with 12.5 domes.I did change locks,springs and retainers because of the radical cam and solids with 4 speed.Mine have been worked some.No complaints after 3 years.Rocky
Chrysler Firepower
Re: 440 Source Stealth Heads [Re: JoesMopar] #918350
02/01/11 08:55 AM
02/01/11 08:55 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
They will be fine, but as said you need to up the compression. I'm using the KB400 .040 pistons .024 below the deck and running a Comp cams 275DEH 235/482, Holley 3310, 1 3/4 headers, 3:55 sure grip, and 2400 stall. My heads were cc'd at 86 and I had them milled .030 bringing them to 80. I'm at 9.9 to 1 compression. Camquest says 430 horsepower. I'm thinking more like 400.
You need to measure first the actual comp. now.
You could mill your block .020 and be .004 below the deck and use the .039 Felpro gasket.
Re: 440 Source Stealth Heads [Re: ireland383] #918351
02/01/11 09:12 AM
02/01/11 09:12 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dont just bolt them on either.Have a good shop check them first.Its money well spent.Rocky
Chrysler Firepower
Re: 440 Source Stealth Heads [Re: therocks] #918352
02/01/11 11:27 AM
02/01/11 11:27 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Yes, My Stealth heads were excellent, good seats everything looked good BUT they were assembled dry as in no oil on the guides at all
So if they had NOT been checked they would have been dry started the valve guides, either seized or excessive wear.
Un-ported out of the box Stealth / Edelbrock flow better than any stock or even mildly ported big block head
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: 440 Source Stealth Heads [Re: JoesMopar] #918353
02/01/11 11:35 AM
02/01/11 11:35 AM
NY usa
540challenger Offline
NY usa
Doesn anyone have any dyno time on the cast verse ALum head HP loss.
There was a chevy write up on Cast iron VS ALum head "same casting but different metals" and the difference was little to none.
I think the big difference in HP loss with ALum is when running the All Alum. engines and only in the big HP range to have any major drop in HP
found the write up
http://www.carcraft.com/techarticles/ccr...no_results.html
Re: 440 Source Stealth Heads [Re: HemiRick] #918354
02/01/11 11:38 AM
02/01/11 11:38 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
So taking a 440 (10:1) with 906 heads, popping em off and putting on Eddy heads would lead to problems?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 440 Source Stealth Heads [Re: Pyper70] #918355
02/01/11 11:46 AM
02/01/11 11:46 AM
NY usa
NY usa
NO with Alum heads you can run a point higher and run on pump gas is the general rule. However every engine combo is different so i wouldn't even use that rule.
Re: 440 Source Stealth Heads [Re: Pyper70] #918356
02/01/11 12:30 PM
02/01/11 12:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Problems? No.
HP loss ... hard to say. If you were comparing two IDENTICAL castings where the only difference was cast iron vs aluminum then there might be a HP loss with the aluminum because of heat loss.
However, there is no aluminum head that is a plain ol' copy of an iron head. Even the base 440Source head flows better out of the box, has larger valves than stock and will provide higher compression with its closed 80cc chamber design.
There's no reason bolting on any aluminum head should cause any power loss unless the head is a clear mis-match to the application - like bolting a B1 head on a stock 440 !!
Re: 440 Source Stealth Heads [Re: JoesMopar] #918357
02/01/11 01:26 PM
02/01/11 01:26 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Only do a light clean up on the valve pockets, unshroud the valves a bit in chambers and do a gasket match on intake side. No reason to enlarge the port to big, will only work against you with the cam size. You need to change the locks, retainers, and springs to fit the more agressive lobe of the XE274 put springs in around 120 on the seat and remember to use Brad Penn 30 weight or equal oil for break in. Check retainer to guide top clearance with seals. Also advance the cam 4 degrees and make sure you have enough gear and convertor if automatic. Compression ? have your machine shop look at what pistons are available at what compression with the head cc. you will possibly have to mill the heads to get better compression ratio.
logan426
Re: 440 Source Stealth Heads [Re: Stanton] #918358
02/01/11 01:38 PM
02/01/11 01:38 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
What were the old Stage IV heads? I never liked the Edelbrocks from an aesthetic sense. I thought that someone was producing a stock appearing aluminum head though? MP?
Re: 440 Source Stealth Heads [Re: Montclaire] #918359
02/01/11 02:24 PM
02/01/11 02:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
The Stealth is the stock appearing alum head
Re: 440 Source Stealth Heads [Re: MLR426] #918360
02/01/11 10:18 PM
02/01/11 10:18 PM
USA
USA
Thanks for the advice. I thought these heads were a bolt on and go? It sounds like alot of swapping parts that are already assembled on the head. I don't like the idea of swapping the locks, retainers and springs to fit in an XE274 cam which isn't much bigger than the stock one, it seems for $1000 these heads should be able to support that right out of the box. So far the vibe I get is these heads are junk.
Re: 440 Source Stealth Heads [Re: JoesMopar] #918361
02/01/11 10:51 PM
02/01/11 10:51 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
That cam isn't even over 500 lift IIRC. All the stuff on those heads will handle that cam easily. As with any aftermarket head you should have them checked. By the way my machinist checked mine over and was very impressed (changed nothing).
Re: 440 Source Stealth Heads [Re: ireland383] #918362
02/01/11 11:01 PM
02/01/11 11:01 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
This is the exact combo i have in 68 charger i have .047 quench with .039 felpro , but i have the block decked and comp cams 275 HL cam and 2800-3000m ptc converter , runs kick ass w 750 hp vacumm secondary .
1969 Dodge Charger 1969 Dodge Superbee
Re: 440 Source Stealth Heads [Re: cjs69mope] #918363
02/02/11 12:11 AM
02/02/11 12:11 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The parts on those heads are certainly no worse than stock parts. With the cam you intend to use I'd go with the heads as they come but I'd have the valve job checked out for sure.
If your budget can handle it, have 440Source upgrade the retainers and locks and you'll never have a worry.
Re: 440 Source Stealth Heads [Re: Stanton] #918364
02/02/11 10:35 PM
02/02/11 10:35 PM
USA
USA
This is a pretty ignorant question, but what do the locks and retainers have to do with the cam? I understand the springs completely, but how do you know what locks and retainers work on which cams?
Page 1 of 4 1 2 3 4
