Electronic ignition conversion help needed ...... #918128
01/31/11 05:19 PM
01/31/11 05:19 PM
PA - Phila
71GRANCOUPE Offline OP
PA - Phila
I am looking to do an electronic ignition conversion to my slant 6 Barracuda. I have seen kits for V8 engines but seems that nothing is listed for a Slant 6. Can i use the same kit?
Has anyone used something different. I need to replace the distributor when i do the conversion -- there is too much play in it from wear over the years.
I am looking for something simple -- any suggestions would be appreciated (but I am not able to swap out the /6 for a V8 any time soon -- no funds, know how, and no V8 to put in yet !!
68 Barracuda Conv
Re: Electronic ignition conversion help needed ...... [Re: 71GRANCOUPE] #918129
01/31/11 05:49 PM
01/31/11 05:49 PM
Central TX
roe Offline
roe  Offline
Central TX
maybe a pertronix kit for it it they have one. Everyone here has nothing but positive things to say about their conversions.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Electronic ignition conversion help needed ...... [Re: roe] #918130
01/31/11 06:14 PM
01/31/11 06:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Go to a jy and find a mid 70's /6 and take out the electronic distributor. the rest is the same as a v8
Re: Electronic ignition conversion help needed ...... [Re: MoparforLife] #918131
01/31/11 06:50 PM
01/31/11 06:50 PM
the house on the left.
cogen80 Offline
cogen80  Offline
you can buy a rebuilt dizzy for like $40 at rock auto. just look up a 74 dart or something. then all ya need is the ecu which can be bought at rock auto as well or just about anywhere then the harness which is $23 here. http://chucker54.stores.yahoo.net/wirharcopand.html
Re: Electronic ignition conversion help needed ...... [Re: MoparforLife] #918132
01/31/11 07:00 PM
01/31/11 07:00 PM
& take both sides of the dist plug in connector and grab the ECU pentastar connector w several inches of pigtail then go to your parts house & get a new $15 4 pin ECU (standard motor products is a excellent brand or whatever they have avail) and w some wiring and the diagrams in the archives you'll have all you need. I would highly suggest opening the dist & clean it & toss the thick spring w the long loop and add one out of the MP light spring kit or another stiffer one if you have one avail. IDEAL would be to find the initial timing amt that your engine likes RIGHT NOW (use the vac gauge method) then do the swap & shorten the slots to give 32 total (vac adv disconnected) but you need the ideal initial amt first to do the math. 32 minus initial=slot length needed. EDIT: forgot to mention, you can keep your orig coil/ballast. slot length chart is in the archives also. It's not dead on but close enough to get you started & #1 is to get the initial correct
Re: Electronic ignition conversion help needed ...... [Re: 71GRANCOUPE] #918133
02/01/11 02:32 AM
02/01/11 02:32 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Ignitions by itself has nothing to do with cilinders number really, is just performance added on EACH spark, no matter if 4, 6, 8, 10... sparks per cicle.
Of course some boxes have a higher or lower limiter threshold than others, the you match with your engine the one you want
Re: Electronic ignition conversion help needed ...... [Re: 71GRANCOUPE] #918134
02/01/11 02:39 AM
02/01/11 02:39 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Mopar did have an electronic ignition kit for the 225.. #P3690789
You might check E-Bay or Mancini for old stock..
On E-Bay is an NOS distributor for $99..
http://cgi.ebay.com/ebaymotors/CHRYSLER-...sQ5fAccessories
Just my $0.02..
