Aftermarket RPM guage... #917485
01/30/11 08:13 PM
01/30/11 08:13 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
where would it hookup? I already have an aftermarket oil pressure, coolant temp, and voltmeter set, but I want a simple on for my engine RPM's. Probably will just grab one from Autozone but need to know where it hooks up at
thanks
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Aftermarket RPM guage... [Re: roe] #917486
01/30/11 09:12 PM
01/30/11 09:12 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Negative side of the coil. And of course a switched positive, a light positive (that illuminated the tach when you turn on the lights--if you tap into the dash light power then your dash dimmer switch will also control tach lighting), and a ground.
Re: Aftermarket RPM guage... [Re: roe] #917487
01/30/11 10:34 PM
01/30/11 10:34 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
In that era, the orange wiring is for the lights.
I want my fair share
Re: Aftermarket RPM guage... [Re: SomeCarGuy] #917488
01/31/11 12:17 AM
01/31/11 12:17 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A new tachometer will come with instructions on how to wire it.
