Page 4 of 4 1 2 3 4
Re: Sealed Hood to Air Pan [Re: StewartP] #917205
02/01/11 07:39 PM
02/01/11 07:39 PM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
Re: Sealed Hood to Air Pan [Re: StewartP] #917206
02/01/11 07:40 PM
02/01/11 07:40 PM
StewartP Offline
StewartP  Offline
E
Re: Sealed Hood to Air Pan [Re: StewartP] #917207
02/01/11 10:15 PM
02/01/11 10:15 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Were there vacuum / diaphram type actuators on these doors??
If you like drag racing, support your local track.
Re: Sealed Hood to Air Pan [Re: CHAPPER] #917208
02/01/11 10:40 PM
02/01/11 10:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The ones I seen had nothing... a flat plate with a
small piano hinge on the top
Re: Sealed Hood to Air Pan [Re: MR_P_BODY] #917209
02/01/11 10:49 PM
02/01/11 10:49 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If the doors came open,,I would think the scoop opening must have been too small then. That would take ALOT of vacuum,,,
Re: Sealed Hood to Air Pan [Re: CHAPPER] #917210
02/01/11 11:33 PM
02/01/11 11:33 PM
StewartP Offline
StewartP  Offline
The hinged scoop, was angled down, from top plate towards bottom, -- allowed the scoop to open at wide open throttle, and very slow speeds. As the speed increased, the doors closed by gravity and were pressurized by velocity -- interesting but marginal effective. Like the blow-doors on a jet fighter.
Re: Sealed Hood to Air Pan [Re: StewartP] #917211
02/02/11 12:04 AM
02/02/11 12:04 AM
Illinois
gearhead01 Online content OP
gearhead01  Online Content OP
Illinois
Thanks everyone for all of the information. Lots of great input.
Based just on cool air, I am going seal up my scoop. I plan to use an air cleaner, using the base of the air cleaner to mount the air pan. Worst case, I can always take it off.
If I can, I will devise in a monometer to measure the actual pressure in the sealed portion of the air pan.
Thanks again, John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Sealed Hood to Air Pan [Re: gearhead01] #917212
02/02/11 11:52 AM
02/02/11 11:52 AM
Az
Crizila Offline
Crizila  Offline
Az
Thanks again, John
COOL Here is how I did mine. Filter on:
Fastest 300
Re: Sealed Hood to Air Pan [Re: Crizila] #917213
02/02/11 11:53 AM
02/02/11 11:53 AM
Az
Crizila Offline
Crizila  Offline
Az
Filter off
Fastest 300
Re: Sealed Hood to Air Pan-Updated [Re: Crizila] #917214
02/08/11 11:50 PM
02/08/11 11:50 PM
Illinois
Illinois
Designed and made a posterboard mock-up/template. Will fit it up this weekend to the hood, and then use template to make up the air pan.
I went to a tapered side design to give more access around the underside near the carb. And, give more airflow room around the air cleaner.
John
Re: Sealed Hood to Air Pan-Updated [Re: gearhead01] #917215
02/09/11 12:11 AM
02/09/11 12:11 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Sealed Hood to Air Pan-Updated [Re: Ari440] #917216
02/09/11 12:33 AM
02/09/11 12:33 AM
Illinois
Illinois
Ari:
Looks neat. DO you have a foam seal on the bottom of the hood?
John
Re: Sealed Hood to Air Pan-Updated [Re: gearhead01] #917217
02/09/11 12:52 AM
02/09/11 12:52 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Ari:
John
no foam
I found a stop sign and made a handle to bolt it down on the carb stud
with my stage 4 heads M1 two inch adapter and 1050 it was even/ flush with the sixpack hood
at the time was running 11.00s ,with the airpan went 10.85 123 mph
this was 10 years ago cant use it with the indy heads I have now
it was free and it got me a 10.85 pass
1.39 9.85 - 137 mph
Re: Sealed Hood to Air Pan-Updated [Re: Ari440] #917218
02/09/11 12:55 AM
02/09/11 12:55 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Sealed Hood to Air Pan-Updated [Re: Ari440] #917219
02/09/11 11:13 AM
02/09/11 11:13 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Poster board & card board is what I use to make all my templates from also. Fewer mistakes that way.
I just saw where Tuff Paw is making scoop trays now. Might be a good place to buy from or get some good ideas.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Sealed Hood to Air Pan-Updated [Re: MRMOPAR622] #917220
02/10/11 06:02 PM
02/10/11 06:02 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I used 2x2" air conditioner sealing foam from the local hardware to seal mine but Moroso has a foam kit that I believe is 1 3/4" thick by about 4" wide and maybe 2-3' long you can buy and trim to fit
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Sealed Hood to Air Pan-Updated [Re: G-Money1320] #917221
02/10/11 07:59 PM
02/10/11 07:59 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My 6pak scoop is only 3" tall and the carb air horns are close but I still get a half tenth out of sealing it. My pan is huge like Stroker Scamps.
Re: Sealed Hood to Air Pan-Updated [Re: ProSport] #917222
02/10/11 08:29 PM
02/10/11 08:29 PM
indiana
moparbrown14 Offline
indiana
boy its hard to find an aluminum stop sign that doesnt have any dents in it lol
Re: Sealed Hood to Air Pan [Re: gearhead01] #917223
02/10/11 08:45 PM
02/10/11 08:45 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We picked up 1.5 MPH but no ET when we did ours
Page 4 of 4 1 2 3 4
