Re: Sealed Hood to Air Pan
[Re: StewartP]
#917205
02/01/11 07:39 PM
02/01/11 07:39 PM
Posts: 2,031 Florida
StewartP
Mopar Vintage Picture Guy
[Re: StewartP]
#917206
02/01/11 07:40 PM
02/01/11 07:40 PM
StewartP
[Re: StewartP]
#917207
02/01/11 10:15 PM
02/01/11 10:15 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Were there vacuum / diaphram type actuators on these doors??
If you like drag racing, support your local track.
[Re: CHAPPER]
#917208
02/01/11 10:40 PM
02/01/11 10:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The ones I seen had nothing... a flat plate with a small piano hinge on the top
[Re: MR_P_BODY]
#917209
02/01/11 10:49 PM
02/01/11 10:49 PM
CHAPPER
Belpre,Ohio
If the doors came open,,I would think the scoop opening must have been too small then. That would take ALOT of vacuum,,,
[Re: StewartP]
#917211
02/02/11 12:04 AM
02/02/11 12:04 AM
Posts: 207 Illinois
gearhead01
Illinois
Thanks everyone for all of the information. Lots of great input.
Based just on cool air, I am going seal up my scoop. I plan to use an air cleaner, using the base of the air cleaner to mount the air pan. Worst case, I can always take it off.
If I can, I will devise in a monometer to measure the actual pressure in the sealed portion of the air pan.
Thanks again, John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Sealed Hood to Air Pan-Updated
[Re: Crizila]
#917214
02/08/11 11:50 PM
02/08/11 11:50 PM
Posts: 207 Illinois
gearhead01
Illinois
Designed and made a posterboard mock-up/template. Will fit it up this weekend to the hood, and then use template to make up the air pan.
I went to a tapered side design to give more access around the underside near the carb. And, give more airflow room around the air cleaner.
John
[Re: Ari440]
#917216
02/09/11 12:33 AM
02/09/11 12:33 AM
Posts: 207 Illinois
gearhead01
Illinois
Ari:
Looks neat. DO you have a foam seal on the bottom of the hood?
John
[Re: Ari440]
#917219
02/09/11 11:13 AM
02/09/11 11:13 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Poster board & card board is what I use to make all my templates from also. Fewer mistakes that way. I just saw where Tuff Paw is making scoop trays now. Might be a good place to buy from or get some good ideas.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: G-Money1320]
#917221
02/10/11 07:59 PM
02/10/11 07:59 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
My 6pak scoop is only 3" tall and the carb air horns are close but I still get a half tenth out of sealing it. My pan is huge like Stroker Scamps.
