Page 1 of 4 1 2 3 4
Sealed Hood to Air Pan #917145
01/30/11 03:45 PM
01/30/11 03:45 PM
Illinois
gearhead01 Online content OP
gearhead01  Online Content OP
Illinois
How many have a sealed air pan to their hood scoop? Is it worth the effort?
I have a glass hood with a 6-pack hood scoop. I have been measuring and sketching. I will have to put a panel on the bottom of the hood to reduce the area, and an air pan that is approximately 18" long and 20 inches wide that covers over the intake manifold.
The cooler air will always help, but i will get that with an unsealed scoop. Do you get much more HP from the "ram effect" with the sealed hood scoop?
Thanks for your inputs.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Sealed Hood to Air Pan [Re: gearhead01] #917146
01/30/11 03:53 PM
01/30/11 03:53 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
I did mine last year, didnt have time to try to rejet but i ran my fastest in sig below in hot weather, picked up close to a tenth and 1 mph, heres pic
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Sealed Hood to Air Pan [Re: gearhead01] #917147
01/30/11 04:02 PM
01/30/11 04:02 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
John
ZERO ram effect with a 6 pak scoop. I repeat, ZERO.
Re: Sealed Hood to Air Pan [Re: BobR] #917148
01/30/11 04:09 PM
01/30/11 04:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
+1
Don't even consider any ram effect, there is nothing there to consider.
It will prevent the carb from sucking in hot underhood air, and that's all. For that reason alone it's well worth doing....it makes a noticeable difference on most cars, and it did on mine.
Rich H.
Esse Quam Videri
Re: Sealed Hood to Air Pan [Re: ZIPPY] #917149
01/30/11 04:13 PM
01/30/11 04:13 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I sealed mine with an aero type scoop and seen no difference in ET.
Re: Sealed Hood to Air Pan [Re: Quicktree] #917150
01/30/11 05:39 PM
01/30/11 05:39 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
On my 67 Dodge R/T I had a STR-14 intake 2 650 DP Holley carbs.(race-car no air filters) Put a Hemi scoop on it & did not seal it,and it slowed it down bad.I run it with the hood off to see what the problem was,the air blowing across the top of carbs would start pulling gas out the vent tubes. Put a tray on it to seal the carbs picked up.06 in the 1/8 mile.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Sealed Hood to Air Pan [Re: gearhead01] #917151
01/30/11 05:48 PM
01/30/11 05:48 PM
Az
Crizila Offline
Crizila  Offline
Az
John
Fastest 300
Re: Sealed Hood to Air Pan [Re: Crizila] #917152
01/30/11 05:58 PM
01/30/11 05:58 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have to agree, the colder air will help, if nothing else it will keep it from pulling in the hotter air under the hood.
Re: Sealed Hood to Air Pan [Re: Dodgeguy101] #917153
01/30/11 06:18 PM
01/30/11 06:18 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
it helped my 68 satellite,picked up a ET and MPH
with a six pack scoop
i think it is more about reducing hot air into the carb with this scoop
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Sealed Hood to Air Pan [Re: gearhead01] #917154
01/30/11 06:35 PM
01/30/11 06:35 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
John
Here is my set-up for the same application. Seals good,,,still working on getting the #%&!!* thing to work though!! Seems to get TOO much air/turbulence in carb above 50 MPH. I had a thread on this awhile back. The tracks closed before I could do anymore testing to correct problems. Good luck.
If you like drag racing, support your local track.
Re: Sealed Hood to Air Pan [Re: CHAPPER] #917155
01/30/11 08:36 PM
01/30/11 08:36 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Chapper- what brand and size(diameter & drop) is that base of yours?
Re: Sealed Hood to Air Pan [Re: 72demon416] #917156
01/30/11 08:54 PM
01/30/11 08:54 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
K&N 16"... 2" drop. I can use the air filter(3") in there too with the cowl hood. The 6pk scoop won't allow the air filter as it hits at the rear of the scoop.
Re: Sealed Hood to Air Pan [Re: Stroker Scamp] #917157
01/30/11 08:58 PM
01/30/11 08:58 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... picked up close to a tenth and 1 mph...
Same basic results here when going from unsealed scoop to sealed.
Re: Sealed Hood to Air Pan [Re: CHAPPER] #917158
01/30/11 09:05 PM
01/30/11 09:05 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've never run mine with out a sealed scoop.
Filter is usually pretty dry after a weekend of racing though
Chapper; maybe you should try a filter to reduce turbulence
Re: Sealed Hood to Air Pan [Re: CHAPPER] #917159
01/30/11 10:18 PM
01/30/11 10:18 PM
Illinois
Illinois
Chapper:
Yours is a similar set-up to what i am planning. I am using a Moroso air cleaner (14") diameter. I am figuring at least 1-1/2" clearance on each side to the air pan side/seal side walls. This will allow air all around the air cleaner. The 14” diameter wir filter will clear the inside of the scoop, with around an inch to spare.
I can see that the 16:” diameter is just large enough to hit the scoop.
Thanks everyone for the input and pictures. I am going ahead on construction and will post some pictures of the results.
John
Re: Sealed Hood to Air Pan [Re: CHAPPER] #917160
01/30/11 10:24 PM
01/30/11 10:24 PM
Illinois
Illinois
Chapper:
A question about the turbulence. Is this with the cowl hood or the 6 pack hood. I have heard about issues with cowl hoods having turbulence problems. The fix was sealing off the grill openings in front of the windshield. The air turning at the back of the cowl would go down in the fresh air grills and never get into the rear opening of the cowl.
John
Re: Sealed Hood to Air Pan [Re: gearhead01] #917161
01/30/11 10:39 PM
01/30/11 10:39 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Greg/John,,The height of the 3" air cleaner hits at the rear of the scoop. Maybe, the 14" might help, I'll have to do some more checking when I can get the car out of the trailer and into the shop. Also, the turbulence, or 'what ever' that's going on in there, is with the 6 pk hood. It runs fine with the cowl hood. I was trying to get cooler air to the carb when I built the air box/pan. I tried it first with the scooped hood and it was a disaster!! After I reached about 50 mph,,motor just broke up terrible. It sounded like it was drowning with fuel. I let up quickly and slowed down which eased the comotion and I idled back to the pits, changed hood back to the cowl and ran fine the rest of the day. Can't hardly wait for good weather again. I was just getting back into the swing of things!!
Re: Sealed Hood to Air Pan [Re: CHAPPER] #917162
01/31/11 04:23 AM
01/31/11 04:23 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Interesting!! I don't think any of the SS/AH cars have any kind of seal now. All are just open!!!!!!!!!!
Re: Sealed Hood to Air Pan [Re: Frito] #917163
01/31/11 09:41 AM
01/31/11 09:41 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
With respect to the turbulence and an air filter:
In David Vizard's excellent book "Tuning BL's A-Series engine" he cites an example of a downdraft Weber carb sticking through the bonnet of a Mini. It worked terrible. They put on an air filter and a scoop and the problem went away. Seemed to be reducing the turbulence over the carb mouth was the key, and the air filter helped a lot there.
Plus there are all the other benefits of an air filter.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Sealed Hood to Air Pan [Re: David_in_St_Croi] #917164
01/31/11 10:09 AM
01/31/11 10:09 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yeah, that 6-pack scoup, sealed like StrokerScamp's, did nada for my Dart. For what it's worth. Many years ago, I was waiting in staging with the hood open, and a consistant winner walks by, and says, sealed hood eh?, walks on by. I started thinking about that, and my theory is, without the seal, the engine is getting a blend of average air. Round to round, it seemed to make the car tighter. That's what I think Bruce was getting at. Could be another WAG on my part too
Page 1 of 4 1 2 3 4
