Re: Possible crank damage?
[Re: Dodgem]
#917133
01/30/11 03:49 PM
01/30/11 03:49 PM
Posts: 426 Califor-ni-A!
MrFoFody
Califor-ni-A!
looks like the counter balance has been hitting the pick up! Your not the first if it is!
+1 Cut open you filter and look for an metal particles. Better yet, pull off some rod caps and look for abnormal bearing wear.
[Re: buildanother]
#917139
01/30/11 07:58 PM
01/30/11 07:58 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
The steel cranks sometimes are snotty looking like that.
What size engine is that ? If it's not hitting the pickup then that is a FORGED crank and that's what they look like .
[Re: ireland383]
#917141
01/30/11 09:34 PM
01/30/11 09:34 PM
JohnRR
U.S.S.A.
71 383 2 barrel with a 70 stamped date.
70 stamped date meaning a 70 ASSEMBLY date ?
What balancer does it have on it ?
Do you have a vibration problem you are chasing ?
[Re: JohnRR]
#917142
01/30/11 09:57 PM
01/30/11 09:57 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Yes assembly date. Has an aftermarket balancer. No weights Had a vibration, but found a real loose pinion nut. Which pretty much happened all of a sudden. Which is why I did not think it was engine related.
[Re: ireland383]
#917143
01/31/11 11:28 AM
01/31/11 11:28 AM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
It looks like a normal steel crank.
Rich H.
Esse Quam Videri
