727 - soft shifts #917096
01/30/11 02:12 PM
01/30/11 02:12 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
I have a 727 behind a 340 that I installed a couple of years ago. It was fully rebuilt a few years before I bought it. It had never been used before I bought it. It was done by a quality shop for the purpose of drag racing and had a forward manual valve body installed. It worked great since I started using it, very positive shifts with zero overlap and it would always chip the tires on 1-2 shifts. Near the end of last season I took the car to the drgstrip and I noticed that the trans was shifting into 2nd by itself. I chalked it up to a loose linkage which was allowing the selector to jump into 2nd by itself. The problem is for the rest of the season I noticed the 1-2 shift was much softer and I would have to really jump on it to get any rubber from the 1-2 shift and it felt like there was some mild overlap between 1-2 before it would fully shift. My hope is that it just needs a band adjustment. Does this sound right or is there something else that could be the issue.
Re: 727 - soft shifts [Re: dd340] #917097
01/30/11 02:25 PM
01/30/11 02:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like time for a fluid and filter change along with the band adjustment.
Re: 727 - soft shifts [Re: stumpy] #917098
01/30/11 02:29 PM
01/30/11 02:29 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
A soft shift like you describe from a previously hard shifting trans. could indicate some loss of hydraulic pressure from leaking seals or rings. If you have a pressure gauge it could tell you a lot.
Re: 727 - soft shifts [Re: 469runner] #917099
01/30/11 05:25 PM
01/30/11 05:25 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
x 2 .. on a line pressure check. How is your fluid ?
Re: 727 - soft shifts [Re: dd340] #917100
01/30/11 06:12 PM
01/30/11 06:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A firm 1-2 shift relies on a properly adjusted kickdown band, check that first.
Re: 727 - soft shifts [Re: John_Kunkel] #917101
01/30/11 06:46 PM
01/30/11 06:46 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
Is that still applicable on a manual valve body?
Re: 727 - soft shifts [Re: dd340] #917102
01/30/11 08:30 PM
01/30/11 08:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep.
Re: 727 - soft shifts [Re: John_Kunkel] #917103
01/30/11 08:35 PM
01/30/11 08:35 PM
scratchnfotraction Offline
