I run a stock windage tray/oil pan with 2 cork gaskets
stock bolts are fine,just dont crush/squeeze the gaskets out by over torqueing
I run a thin coat of copper rtv on both my gaskets and let cure over night before running engine
you can go to oil pan studs if you dont like the stock bolts,very nice when its on the engine stand and fliped upside down for the pan install
make sure to check oil pick up tube and bottom of the pan for correct placement
I had to tweak my pick up tube just slightly to clear the tray in one spot
double check before it goes in the car/truck
![](/ubbthreads/images/graemlins/thumbs.gif)
