68 B Body black inner door panel paint? #91682
07/20/08 08:59 PM
07/20/08 08:59 PM
Indianapolis
Waveraider Offline OP
Indianapolis
OK. I'm "attemping" a color change on my 68 Satellite and am painting the top and bottom of the inner doors black. I would like for it to look like what you see below. What has anyone who's done this used? Gloss from a spray gun? Rattle can? Semi Gloss? Thank you in advance.
Re: 68 B Body black inner door panel paint? [Re: Waveraider] #91683
07/21/08 07:21 AM
07/21/08 07:21 AM
i believe you paint that with same exterior paint,it was painted same time as exterior.
Re: 68 B Body black inner door panel paint? #91684
07/21/08 10:35 PM
07/21/08 10:35 PM
Indianapolis
Indianapolis
I am trying to get the same results as this.
I ended up buying some Black Acrylic Enamel at the auto paint store and shot it tonight. Turned out allright.
Re: 68 B Body black inner door panel paint? [Re: Waveraider] #91685
07/22/08 12:00 AM
07/22/08 12:00 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Gloss finish, color-coded to interior scheme. They were not the same color as the exterior in most cases (black/black being one exception), and were painted at a separate time. Colors separated at the weatherstrip.
Re: 68 B Body black inner door panel paint? [Re: topside] #91686
07/22/08 02:18 PM
07/22/08 02:18 PM
Indianapolis
Indianapolis
that's pretty much the way I did it. I'll finish the drivers side tonight. Thanks.
Re: 68 B Body black inner door panel paint? [Re: topside] #91687
07/22/08 02:18 PM
07/22/08 02:18 PM
Indianapolis
Indianapolis
