Page 3 of 3 1 2 3
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916506
06/17/11 11:35 PM
06/17/11 11:35 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Original air cleaner came out really nice.
Installed a new dist / oil pump drive shaft today. Filled it up with 5 qts of 10-w30 , and prelubed the crap out of it, including while spinning it by hand
And I wanted to jump for joy.,with absolute minimul effort , It started on the 1st revolution with the key on. Didn't have to monkey with the dist, carb, wiring , NOTHING.
I had it running with NO issues, NO leaks, and with exception to an exhaust leak at the headpipe to manifold , even No noises. not a lifter or piston noise to be heard anywhere. Owner was concerned . And given the fact I didnt build it,I was maybe just a little bit .
But ,,,,,,,for the 1st time in a LOOOOOOOOOOONG time it lives.
Soon as it started , I bumped it up on fast idle, and let it run maybe 15-20 minutes to break in the cam.
Per the factory gauges , it never tried to get hot, and had just over 60 lbs of oil pressure on high idle.
Sounds really good, at roughly 800 rpm in neutral it sounds a lot like a stock cam. But it's just the old H-pipe and mufflers with no tailpipes till I can get it to the exhaust shop . Buddy of mine is a mgr of a midas and he says he replicate the factory H-pipe exhaust in 2.5" pipe from manifold to tips.
And with a little luck, It'll pull itself out of the garage by the 1st of the week. Under it's own power,,,,, for the 1st time in a long time.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916507
06/18/11 01:27 AM
06/18/11 01:27 AM
QLD Australia
Keith Black® Offline
QLD Australia
Great work!! keep the pictures coming!
Darren Beale
Keith Black Racing Engines®
Re: 1969 Charger R/T - Let the journey begin [Re: Keith Black®] #916508
06/22/11 10:12 AM
06/22/11 10:12 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Although it is an original Bendix cisc brake car. It was thought best to convert it to something a wee bit easier to get parts for on the road trips. (and there are many in this cars future )
Using newer F-body slider type brakes, and per DR DIFF I used a 69 GM flex hose. It all fits with no signs on chassis interference.
Everything is new, 2 rotors, 2 calipers, all the wheel bearings and seals .
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916509
06/22/11 10:15 AM
06/22/11 10:15 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Original driveshaft - replacing both U-joints.
After spending a little time in the glass bead cabinet and then repainted .
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916510
06/22/11 10:16 AM
06/22/11 10:16 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ft joint felt a little rough, so both were replaced.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916511
06/22/11 10:19 AM
06/22/11 10:19 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I picked up an aftermkt horn relay and transfered the guts to a replated original can.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916512
06/22/11 10:19 AM
06/22/11 10:19 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Pardon the dust.
Page 3 of 3 1 2 3
