45 rfe transmissions #916404
01/29/11 01:07 PM
01/29/11 01:07 PM
norway
aufles.mopar Offline OP
norway
is it anyone who know if i could bay a new electronic and wiring for these transmissions,i wanted to put it into my 1933 plymouth hotrod with 5.7 hemi
1971 cuda and 1934 plymouth hotrod
Re: 45 rfe transmissions [Re: aufles.mopar] #916405
01/31/11 01:57 AM
01/31/11 01:57 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
http://www.thehemi.com/newhemiswap.php
I'm not sure about a 45rfe but when it later became the 545 rfe it was used behind the 5.7 hemi
http://www.hotrodlane.cc/34plymouth/33dodgehemi1.htm
The 2nd link is similar to what you're doing there.
Hope that helps
Re: 45 rfe transmissions [Re: BEINGmeISaCRIME] #916406
02/01/11 07:33 PM
02/01/11 07:33 PM
norway
norway
i have checked som out. tci have the controller and wiring for 45 rfe/5-45rfe transmissions.
thanks for the reply 72charger
Re: 45 rfe transmissions [Re: aufles.mopar] #916407
02/01/11 07:37 PM
02/01/11 07:37 PM
norway
norway
is it the same bellhousing on the 4.7 engine as the 5.7 engine.i found alot more transmissions for the 4.7 than the 5.7 hemi.contoller doesent mather because i'm going for the tci or megasquirt
Re: 45 rfe transmissions [Re: aufles.mopar] #916408
02/01/11 07:54 PM
02/01/11 07:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The 45RFE and the 545RFE are the same transmissions. The only difference is in the electronics as the 545RFE controller just added a gear by applying different clutches to get another gear ratio. Ron
Re: 45 rfe transmissions [Re: 383man] #916409
02/01/11 08:00 PM
02/01/11 08:00 PM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
I spoke with TCI several month ago, they told me there was no stand alone computer for this trans. I have a 04 5.7Hemi and a 5-45RFE. I am using the factory computer to manage the system.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: 45 rfe transmissions [Re: Bakaruda] #916410
02/02/11 05:11 AM
02/02/11 05:11 AM
norway
norway
i was i contact with tci and them told me that they dont have a controller for this transmission.but everywhere they sell these 377500 controller they advertised them to 45rfe and they also have the 377505 chrysler 45rfe-545rfe wiring harness for it.i'm litlebit confused now.
Re: 45 rfe transmissions [Re: aufles.mopar] #916411
02/02/11 01:14 PM
02/02/11 01:14 PM
norway
norway
i got a message from TCI.they have been taken those parts out of the marked.megasquirt say that their computer could controll the 45 rfe transmission but nobody have tryed it yet.
does anybody else know about any controller that works on this transmissions?
Re: 45 rfe transmissions [Re: aufles.mopar] #916412
02/06/11 07:50 PM
02/06/11 07:50 PM
norway
norway
nobody who have tryed to use this transmission without the original electronic?
