Balancing Question
#916305
01/29/11 11:51 AM
01/29/11 11:51 AM
Posts: 1,532 off the grid
340B5
off the grid
Planning a new engine and one thing leads to another The new rods/ pistons I want to use will be 435 grams (per rod/piston) lighter than the old ones. This adds up to 7.658 lbs. Can that much weight be taken off of a standard weight crank? Or do I have to buy a lighter one. This is SB, and the std wt. crank is 58 lbs. The lighter one is 52 lbs. Thanks
Yeah, it's got a smallblock.
Re: Balancing Question
[Re: 440Jim]
#916307
01/29/11 12:48 PM
01/29/11 12:48 PM
340B5
off the grid
Thanks, I went looking @online catalogs for bobweights listed a few minutes last night. I know I seen #'s listed somewhere.
[Re: Cab_Burge]
#916310
02/07/11 03:16 PM
02/07/11 03:16 PM
340B5
off the grid
Looks like good news although I'm kinda puzzled by it. The Std wt crank will work. Found the big/small end weights (440g/180g) and they figured bobweight to be around 1790 grams. The balancing bobweight for their cranks are;
Std.wt~1800grams Lt. wt.~1650-1700 Super lite~1600 This is for 340 main/3.58 stroke Scat crank.
I'm curious as to what the weight of a factory 340 (forged) crank is now. Maybe a trip to the garage w/ the bathroom scale is in order.
