SB Chevy rocker arms on a Magnum head? #916138
01/29/11 12:55 AM
01/29/11 12:55 AM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
I have pretty much gathered up all the parts needed to swap Magnum heads onto my 78 360. I have been reading about the use of small block Chevy 1.6 roller rockers on Magnum heads. If rollers would work, wouldnt 1.6 ratio stamped steel rockers work as well? Summit sells 3/8" stud kits for as little as $12, and a set of 1.6 ratio stamped steel rockers for $61. I have always liked the idea of adjustable rockers with a hydraulic cam, especially when a custom length pushrod is to be used. Also, am I correct in assuming a 1.5 ratio arm wont work? This is all going on a 78 360 shortblock with a Comp XE256 cam. Could I use the stamped steel units, or do they have to be rollers?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916139
01/29/11 01:00 AM
01/29/11 01:00 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Drpending on what you will do, stamped steel will work
Re: SB Chevy rocker arms on a Magnum head? [Re: Wedgeman] #916140
01/29/11 01:03 AM
01/29/11 01:03 AM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Its just a cruiser. I picked up a set of brand new Magnum heads for free, and a dual plane Magnum M1 for next to nothing. Im just messing around with it and maybe looking to get a little more out of it. Its in a 4000lb 78 Fury so its not a strip terror or anything like that. Should I go ahead and still plan on using the aftermarket 7.65" pushrods as well too?
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916141
01/29/11 01:11 AM
01/29/11 01:11 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Remember, you need rods that oil trough, and lifters that do the same job
Dan
Re: SB Chevy rocker arms on a Magnum head? [Re: Wedgeman] #916142
01/29/11 01:20 AM
01/29/11 01:20 AM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yeah the Comp lifters have the oil hole, and I do have the correct oil-through pushrods already. Am I stuck using 1.6 rockers, or can I use 1.5 ratio? The only reason I ask is because the 1.6s will increase my lift to .477/.485", and with 1.5s it is .447/.455". The advertised duration is 256/262, and at .050" it is 212/218. The car weighs 4000lbs, and Im running a 2400 converter, 3.21s, headers and 2 1/2" duals. I dont want to have any kind of a rough idle or lose what little bottom end I do have when I need to get this boat moving.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916143
01/29/11 01:51 AM
01/29/11 01:51 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You can run the chevy rockers and the 1.5 ratio will work. I'd just slap the stock magnum rockers on it and call it a day.
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916144
01/29/11 01:56 AM
01/29/11 01:56 AM
IN
ahy Offline
ahy  Offline
IN
The 1.6 ratio rockers shouldn't affect idle quality much. That's petty much determined by cam timing which is not radical at all. The 1.6 rockers should not hurt low end torque much either... and should increase mid-upper range torque. As long as the valvetrain is set up for 1.6 with correct pushrod length and clearanance, it should be a plus vs 1.5.
Re: SB Chevy rocker arms on a Magnum head? [Re: ahy] #916145
01/29/11 03:45 AM
01/29/11 03:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You guys DO realize that the MAGNUM 5.2 and 5.9 engines came with 1.6 ratio rocker arms, right? Factory stock and cheap.
Re: SB Chevy rocker arms on a Magnum head? [Re: Kern Dog] #916146
01/29/11 10:32 AM
01/29/11 10:32 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
I use Magnum heads with the stock rockers (1.6)on a 360 with a Comp XE268 cam in my Duster. Idle is quite smooth and low end torque is plentiful. With a 256 I can't imagine a problem. Set up your Distributor so initial is at least 16 Degrees (mine is 19). Up to the point of spark knock the most advance will give you more low end grunt. I even use the stock converter. With the 2400 converter it may appear to be weak on the low end but I doubt it. That's pretty close to a factory performance converter. My Stepson has a 2800 in his roadrunner with the 268 cam and complained about this until I had him brake it to raise RPMs before launch. Kind of like slipping a clutch. After he had some seat time with it, he was happy.
Drive ind enjoy it
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: SB Chevy rocker arms on a Magnum head? [Re: Kern Dog] #916147
01/29/11 11:42 AM
01/29/11 11:42 AM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yes, I'm quite aware of that. Let me try this again. The whole point of the post was to see if I could use SBC rockers on my Magnum heads. I want to use an adjustable rocker arm. I was concerned about the idle quality when using THE STOCK 1.6 rockers and the cam I'm running. That's why I asked about the use of 1.5s. You can read all of this in the previous posts above
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916148
01/29/11 12:40 PM
01/29/11 12:40 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Just use the 1.6.......
I would really use a higher stall though
Re: SB Chevy rocker arms on a Magnum head? [Re: Wedgeman] #916149
01/29/11 01:17 PM
01/29/11 01:17 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Thats the thing though. I dont want to run a higher stall or run some ridiculous low gears. This is a daily driver that Im just looking to get a little more power and torque, and take advantage of some of the benefits Magnum heads have to offer. I repeat, this is not a race car, and Im not loking to turn it into one. Its a stock 78 360 shortblock with an XE256 cam, headers and duals. But if the 1.6s would be better, then then Ill just go ahead and run them.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916150
01/29/11 01:53 PM
01/29/11 01:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is just like going to an all Mopar show and seeing a beautiful 34 Plymouth coupe with a small block Chevy.
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916151
01/29/11 01:54 PM
01/29/11 01:54 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I don't think you'll see enough difference to even worry about.
Re: SB Chevy rocker arms on a Magnum head? [Re: slantzilla] #916152
01/29/11 08:11 PM
01/29/11 08:11 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
Th 1.6 rockers will increase th grunt factor across entire rpm range and I bet hav no noticeabe effect on idle quality, go for it
Re: SB Chevy rocker arms on a Magnum head? [Re: racincuda] #916153
01/30/11 06:44 PM
01/30/11 06:44 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
1.6 will only help not hurt in any way. Just slap the stock rockers on it and sleep well at night. I too have an XE268 with magnum heads on a 360 in my 68 cuda, 2.76 gears and stock 318 2bbl tq converter and it does not lack any TQ off idle even with an M1 single plane intake. Your cam is several sizes smaller and you have a dual plane intake so low speed TQ will not be an issue with the factory 1.6 rockers. If you want to run the chevy rockers you will also need guide plates that are magnum specific or some kind of adjustable ones, the stock ones don't use any of that junk.
Re: SB Chevy rocker arms on a Magnum head? [Re: HotRodDave] #916154
01/30/11 06:49 PM
01/30/11 06:49 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
You're using the GM 3.1/3.4 springs and retainers too, correct?
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: SB Chevy rocker arms on a Magnum head? [Re: 69L78Nova] #916155
02/01/11 12:46 AM
02/01/11 12:46 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
YUP!
Re: SB Chevy rocker arms on a Magnum head? [Re: HotRodDave] #916156
02/01/11 12:33 PM
02/01/11 12:33 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
point of reference, in my 3950lb 5th ave, I had an LA 360 with a comp XE262 (~8:1) compression, 3.55's, and a MP166k converter that brake stalled to ~23-2400, flashed to 2800. moved the car along just fine. would light them up at will.
switched to a magnum headed 318 with a 259/259 roller, .506" gross lift, using hughes #1110 springs and stock magnum rockers. has the same power as the 360, would prefer the MP166k converter, but lives with the stock, low stall (~1400rpm stall) converter because of a crack I found in the snout of the 166k.
you'll be fine with the stock magnum rockers, GM3.1/3.4L springs or the hughes springs w/2.2L retainers with the gear, stall, & weight. with headers, it'll be a low-mid 14 second car, maybe even nipping into the 13's.
2017 Grand Cherokee Overland
Re: SB Chevy rocker arms on a Magnum head? [Re: patrick] #916157
02/01/11 05:00 PM
02/01/11 05:00 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, I already have the headers, 2.5" duals, 2200-2400 converter, and a 3.21 sure grip. Do you really think it would run that good with the stock pistons? I obviously can't use a spreadbore carb on the M1, so do you think a 600 Edelbrock will be ok? What do you think of the Hughes 7.64" pushrods?
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
